brakes
Old Jun 2, 2005 | 03:01 PM
STLMINI's Avatar
STLMINI
brakes
next weekend (june 11) i'm taking off the drums all around on my classic mini for the first time to replace the shoes and springs (and at least one cylinder in the rear)... does anyone have any suggestions/warnings/advice?
Old Jun 2, 2005 | 06:40 PM
Minimad's Avatar
Minimad
You may have difficulty with the rear adjusters. Start spraying them now with PB Blaster. If they are stuck, dismantle the brake assembly & heat with propane torch Work back & forth. They unscrew thru the backplate into the shoe side. Clean rust from threads. Coat with antiseize & reinstall.
Watch that your drums are not already turned too far. Another cut may put them over max and you'll lose adjustment & pedal.
Bleeding can be a *****. Don't pump fast. Open bleeders, press pedal, Close bleeders. Repeat slowly. Also try letting gravity work with bleeders open.
Get a proper brake adjuster tool with square holed ends. The adjusters round quickly otherwise.
Replace any cylinder that shows wet inside. Buy new, don't rebuild as they're cheap. Assume if one side is bad then both are....or the other is close behind.
Think about replacing the flexible brake lines while you're at it. Upgrading to SS braided helps brake effort.
Keep everything clean. Use Castrol GT LMA brake fluid.
Drink beer.
Oh, and be patient in placing the wheel cylinder locating clip on the rear....you'll see what I mean
Old Jun 3, 2005 | 08:08 PM
Philthy's Avatar
Philthy
I think this MINIMAD guy should write a Mini repair manual. How's the wagon coming anyway? Will we be able to see it before MiniMeet east?
Old Jun 11, 2005 | 04:22 PM
STLMINI's Avatar
STLMINI
success! almost.
friday afternoon, i got the front brake shoes replaced. the adjusters are toast. they couldn't be any more rounded. i'm not even messing with them.
today (saturday), i did the rear brakes. did the LH side first. everything came off fine, adjuster toast for sure. replaced the cylinder and yes the clip is a beotch. got the drum back on with a little trouble but its on. moved to the right. same story with the adjuster. took everything off. opened the box with the cylinder and darn it if the rubber isn't already ripped. aaarrrghh. everything was going so well. i had to remind my self... patience patience patience.
now i have to wait until monday to call 7 ent to get a replacement cylinder since no one has them in town.
so, the adjusters need replacement. i'll get some new drums and adjusters for sure - that, however, is for another day though.
Old Jun 11, 2005 | 08:37 PM
Minimad's Avatar
Minimad
Sounds like you made good progress. Its common for PO's to use open end wrenches and vice grips on the adjusters (********! ) And you are correct about patience, patience.... Take your time.
Also wanted to correct the bleed sequence (must have had a brain fart ) It was press pedal, open valve, close valve, release pedal. Do it slowly to purge the air. For some reason Mini hydraulic systems can become very persnickety when bleeding. Also, the wheel sequence should be LR, RR, LF, RF. Work your way from the farthest bleeder back to the one closest to the master. You can also pressure bleed if desired. Auto Zone sells a kit.
Old Jun 11, 2005 | 08:49 PM
STLMINI's Avatar
STLMINI
i have a bleed kit. it was when i used it for the first time that i realized that one of my cylinders was bad. i was told by my local mini guru that it could be a cylinder, a collapsed brake line or the a bad spring at the juncture before the rear brake lines. let me just say that when i took the brake line off the suspect cylinder i was glad to see some new fluid drip out. whew!
when i get the replacement cylinder, i'll bleed the brake lines and we'll see what kind of damage i've done!
btw, a friend of mine bought speed bleeders for his bmw mini and i was wondering if they had those for the classic mini? anyone ever used speed bleeders on their classics?
Old Jun 20, 2005 | 08:58 AM
STLMINI's Avatar
STLMINI
brake adjustment repair kit
so, mini mania and 7ent no longer have this kit. does anyone have any idea where i can get one? see attached picture, please.
Old Jun 20, 2005 | 04:08 PM
Minimad's Avatar
Minimad
if you have the part # try bmc.on.ca or minicityltd.com or djminis.com.
after that its off to the UK -> minisport.com or minispares.com
Old Jun 20, 2005 | 08:31 PM
STLMINI's Avatar
STLMINI
minicityltd has it! thanks.
Old Jun 22, 2005 | 10:10 AM
rl48mini's Avatar
rl48mini
you could also try:
http://www.heritagegarage.com/
Bob
Old Jul 27, 2005 | 08:22 PM
STLMINI's Avatar
STLMINI
finally got the brakes 100% done. new adjusters, new springs, drums, stainless steel lines. all i can say is that the car stops and stops hard.
Old Apr 17, 2010 | 05:44 PM
womble's Avatar
womble
I am having a devil of a time getting the retaining clip on the cylinder. Any lessons learned? I spent at least an hour trying today and had to walk away from it. Seems like needle nose vice grips would do the trick, but, of course I don't have any.
Old Apr 18, 2010 | 05:03 AM
Capt_bj's Avatar
Capt_bj
channel lock worked for me
http://www.google.com/products/catal...wAg#ps-sellers
aka groove joint pliers
http://www.harborfreight.com/cpi/cta...emnumber=94287
they allowed a 'flat' squeeze
Old Apr 18, 2010 | 03:44 PM
womble's Avatar
womble
Got some of them. I'll give it a try. Seems like the design could have been a little different, but who am I to complain. I am sure it will go right on at some point, making the second round slightly easier.
Old Apr 20, 2010 | 01:17 PM
womble's Avatar
womble
Thanks for the tip, CAPT. I was trying to hold the clip and push it on and was getting nowhere fast. Using the cylinder protrusion as a fulcrum (I guess) worked much better. Just didn't consider that route.
Old Apr 20, 2010 | 02:13 PM
Capt_bj's Avatar
Capt_bj
always glad to be of help
leverage is your friend
and any excuse to buy another tool is the way I look at it!
Tires, Wheels & Brakes
Sep 10, 2015 12:27 PM
Sep 10, 2015 10:52 AM
Tinklespout
16
Sep 6, 2015 11:39 AM
Sep 4, 2015 09:23 AM
PelicanParts.com
Sep 3, 2015 03:22 PM
