1971 mini
Old May 17, 2016 | 10:45 AM
johnsansone's Avatar
johnsansone
1971 mini
Hi all I have been tinkering with British sports off and on for 40 years, MGA's and B's, recently got a RHD 71 mini from the UK that has not been run for 10+ years, can't get it to idle, got spark, fuel starts but will not idle. Anyone have any ideas?
Will appreciate any help!
Thanks john
Old May 17, 2016 | 11:13 AM
Capt_bj's Avatar
Capt_bj
so you are familiar with SU carb already????
Since you've played with LBCs I don't want to bore you with the super basics ......
I mean the Mini motor is not all that different from a MGB's (B series vs A series ...... they share a lot ...... like SU carbs)
what have you tried already????
Cleaned what?
futzed with what?
PM me if you want to take it off line
Old May 18, 2016 | 05:43 AM
johnsansone
The carb is to modern for me I know SU's, pre 60's I can work with!
JS
Old May 18, 2016 | 12:34 PM
Capt_bj's Avatar
Capt_bj
SU basics shouldn't differ too much. I'm guessing you are used to an HS - side bowl - and you now see the in line bowl? Not any big difference here IMO. The needle remains the key .... but past idle . . . you are familiar with the seat of the pants richness setting? It was just mentioned in another thread here recently ... the one about setting for altitude . . .
Won't idle at ALL, or not at what you would consider a 'normal' RPM? Book says I should idle around 800 but I need to be running for about 20 minutes b4 this happens .... cold idle I need around 1200 ... and after a couple of minutes 1000
First 1/3 of the choke's pull should engage 'fast idle'; doing nothing to the mix.
Have you taken any of the carb apart? I'd at least take the 'pot' off and check for a gummed up piston spring ..... did you flush the fuel system????
Of course a good rule is never mess with the fuel system until 110% SURE the spark is solid. You have spark but is it 'good' ... I'd change the coil and nix the points for a Pertronix . . . wires, cap, rotor . . .
You've checked the timing?
Old May 19, 2016 | 05:55 AM
johnsansone
Thanks GUYS we are cruzzzzing in the MINI!
Old May 19, 2016 | 01:50 PM
Capt_bj's Avatar
Capt_bj
it can be helpful to others, and those who offered help
to learn what the problem and fix was . . .
Old May 19, 2016 | 01:58 PM
Mini Mania's Avatar
Classic Mini Carbs
For anyone needing carb help, we have a whole selection of articles here
http://www.minimania.com/Search_Resu...20carb/default
MidwayMountaineer
Jun 27, 2022 07:39 AM
quickcoop
Dec 4, 2020 09:05 AM
Eurothrasher
May 18, 2016 08:09 AM
AFN704
Mar 23, 2016 10:58 PM
JWA
Mar 20, 2016 07:23 AM
