Why is honing necessary for radium arm rebuild?
Old Aug 28, 2011 | 01:59 PM
jeffm5150's Avatar
jeffm5150
I've replaced my rear dry subframe. Now I'm ready to reinstall the radius arms. In the radius arm repair kit information (online parts catalog) there's a comment that "The bushing must be reamed/honed parallel with the centerline of the pivot hole".
Question 1: Can someone please shed some light on why the radius arm bushing needs to be honed. Or perhaps explain where the bushing is so I can visualize what that comment means.
Question 2: Is the cost of the UK radius arm rebuild kit worth it (compared to the generic rebuild kit)? Both kits require reaming/honing. $25 for generic rebuild kit vs. $50 for Quinton Hazel kit. Advice / suggestions please ...
Thanks,
Jeff
Old Aug 30, 2011 | 04:49 PM
Pflashinaz's Avatar
Pflashinaz
Jeff, hope this helps: http://keith.miata.net/mini/files/radius_arm_short.pdf
Old Aug 30, 2011 | 05:18 PM
jeffm5150's Avatar
jeffm5150
Ok, at least I can visualize it now. Seems odd that the bushings aren't already the correct size considering they're coming with the new shaft. Only thing I can figure is the bushing compresses a little when it's fit in the radius arm.
Anyway, thanks for the link. It was most helpful.
Jeff
Old Aug 30, 2011 | 05:30 PM
Pflashinaz's Avatar
Pflashinaz
Let me know if you want me to contact Simon about the reamer, although it looks like some have had success using a brake hone.
BTW I have a new brake hone if you want it. Got it to do my arms, but when I took them apart the original bushings were in great shape, no play, so I just installed new shaft. I have the older arms with the bushings in both ends.
Old Sep 4, 2011 | 03:45 PM
mk1leg's Avatar
mk1leg
You do not have to ream out old braring.................I used a dramel drill with a tungstem carbide bit and removed the roller bearing casing by gently removing a little at a time till I reached the outer skin the it fell out...crepeated other side washed arm then fitted new plastic sleeve then new bearings...................http://www.minispares.com/Product.aspx?ty=pb&pid=37509 kit reqiured...........
Old Sep 4, 2011 | 04:18 PM
jeffm5150's Avatar
jeffm5150
Again ... ? The original post was asking why there was a need for reaming the new bushings, not the old bearings. Did you even read through the thread posts?
Old Sep 4, 2011 | 06:55 PM
Blackbomber's Avatar
Blackbomber
Because of the interference fit. The bushing gets squished down some after install, hence it's not possible to reliably account for that in manufacture.
Old Sep 5, 2011 | 03:18 PM
mk1leg's Avatar
mk1leg
YES I READ THE ORIGNAL POST......I was just offering a way of installing the new roller bearing caseings with out the use of specialest equipement.....such as a reaming machine.........I used this method and done 6000miles since and had no problems............
PsychoRallye
21
Feb 17, 2019 06:08 AM
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
Fordgt4
Oct 10, 2015 10:42 AM
rt808
Sep 29, 2015 03:15 PM
