1967 Mini mk1 project
Old Oct 14, 2008 | 02:58 PM
  #26
mk1leg's Avatar
mk1leg
Originally Posted by Capt_bj
I disagree that fitting 12's means fit larger brakes....
Usually one has a later Mini with the larger brakes and wants to fit 10" wheels. Here, one must fit the smaller disks because the wheels just WON'T fit over the larger disks.
But going the other way..... If I wanted to fit 13's on my 79 fitted with 7.5's I would not NEED to change to the larger disks altho doing so WOULD provide more stopping power
{BTW...:"The 12" wheel has the same rolling dia as a 10" wheel ..." Sorry: I was a math major and I'm struggling with this one. Now depending on the sidewall height of the respective tires mounted I could possibly agree but otherwise the formula for circumfrence makes it directly proportionial to radius doesn't it? Larger radius = larger circumference....another name for "rolling diameter"? So the wheels have different circumferences..period ...but one could mount tires on a 10 and a 12 that resulted in a hub to street radius that's the same.....in other words a wheel + tire combo for a 10 and a 12 MIGHT be the same}
Sorry I thought Boney was asking ????s as I believe his 1967 mini has 7" discs as opposed to Cooper S wich has a 7.5" disc and the later minis used 8.4" discs AND 10" & 12" wheels do have the same rolling dia Its a well Known FACT amougst the mini family and I don't care if you are a Maths Major I know Mini's I've been Building them for 33 years now ..............
Old Oct 14, 2008 | 03:06 PM
  #27
mk1leg's Avatar
mk1leg
OH by the way Capt_bj the 12" wheel replaced the 10" as they had to comply with British Standards and EU laws as to Braking thats why they used 8.4" discs...........
Old Oct 14, 2008 | 04:53 PM
  #28
boney's Avatar
boney
ok, fella's let me get this straight. If I upgrade to the 7.5 inch brakes I can run either 10 or 12 inch wheels. correct?
If I go to the 8.5 I have to stay with 12 or 13 inch wheels and 10s will not fit? ok?
what if I stay with my 7inch brakes, would 12s fit? sorry dont mean to **** anybody off and I very much appreciate all of your input and knowledge!!!!!!!!!!!
Old Oct 14, 2008 | 05:01 PM
  #29
Mercy's Avatar
Mercy
LOL.. now I have a question. I suppose if a 12" wheel has a tire on it with a low profile and a 10" with a high profile and the diameter were the same, then it would take the same amount of distance to make a full revolution. But if the diameter is larger doesn't that change things? Lets say for a minute you had no tire on it make a mark on each and roll them, a full revolution of the 10" wheel would not go as far as a 12" right? So according to what you are saying mk1leg is the trick is changing the wheel size without changing the tire's diameter. Is this right?
Old Oct 14, 2008 | 06:57 PM
  #30
stratman977's Avatar
stratman977
The 10 or 12 inch is the rim size. The outer diameter of the actual wheel depends on the rim size,section width and the aspect ratio of the tire.
Wheel Diameter=2 X Section Width X Aspect Ratio/2540+Rim Diameter
For example: for a tire size P235/75R15
235=Section Width
75=Aspect Ratio
15=Rim Diameter
Old Oct 14, 2008 | 08:40 PM
  #31
Spank's Avatar
Spank
http://www.ime.org.uk/ime/f/final_drive.html
Check out the chart near the bottom of the link to compare tire sizes and rpms. There's a slight difference, depending on the tire size chosen to compare.
You can put any wheel on a 7" cooper or 7.5" Cooper S disc brake setups. Same with the drum brakes.
With an 8.4" disc setup, you are generally restricted to using 12" or larger wheels.
Standard 8.4" discs stop better than standard 7.5". And both stop better than 7" discs.
--Spank
Old Oct 15, 2008 | 11:51 AM
  #32
boney's Avatar
boney
awesome!!! thanks for that info spank, you the man!!!!
From what I read I probably have a 3.76 ratio. Now time to decide what to do I have to buy new tires anyway. 10's or 12's that is the question.
Old Oct 15, 2008 | 07:48 PM
  #33
Rocan's Avatar
Rocan
GASP!
how could you let your daughter sit on your mini!?
Old Oct 15, 2008 | 08:44 PM
  #34
Mercy's Avatar
Mercy
LOL.. I dont let anyone on my Mini. I saw this model on the top of this one.. I would have had a heart attack. Look at the roof... the ROOF! you know.. the Mini's roof, not hers... I guess this could be considered a Mini Roof Rack:P
Old Oct 16, 2008 | 06:20 AM
  #35
boney's Avatar
boney
awesome picture, keep those coming!!!!!
I noticed you have the same engine in your mini, what setup do you have? final drive, wheel size tire size, etc?
Thanks,
Old Oct 17, 2008 | 08:12 PM
  #36
Mercy's Avatar
Mercy
I used to have 3:44 in it and something happened to that tranny.. the last one I put in had 3:76 I think it is. I honestly didn't see much difference. It took off the line nicely and held highway speeds just fine. I run Yokohama 008 on it now.. They wear too fast so I am going to try something different next. Those are 10 inch wheels. I have a 12g206 head on it and LCB header. I did however just break a crank but that was at pretty low rpms and the car had alot of miles on the engine. More of those pics.. I have a few more of that shoot.. Here are a couple more.
Attached Thumbnails 1967 Mini mk1 project-dscf5143.jpg   1967 Mini mk1 project-dscf5172.jpg   1967 Mini mk1 project-dscf5150.jpg
Old Oct 17, 2008 | 08:35 PM
  #37
dimini's Avatar
dimini
Ouch!
The roof is caved in! Even in the shot of her on the fender/hood, it looks like the hood is mooshed down. I'm calling PETC (people for ethical treatment of cars).
Old Oct 17, 2008 | 08:48 PM
  #38
Mercy's Avatar
Mercy
ROFL.. thats what I am talking about.. I don't care what she looks like.. she can be replaced without welding
Old Oct 18, 2008 | 04:22 AM
  #39
Classic Blimey's Avatar
Classic Blimey
Mercy...Aren't those pics from the crazy Russians? Its funny when I saw those pics the first time I knew I was getting old because I was more worried about the roof too!
Minis only look correct with 10" wheels.Of course I am biased and very old school because I lean toward sliding windows and external hinges too!
Old Oct 18, 2008 | 06:03 AM
  #40
boney's Avatar
boney
it sounds as if we are running the same setup. What rpms are (were) you running ast 65 mph?
Old Oct 18, 2008 | 07:17 AM
  #41
Mercy's Avatar
Mercy
Not really sure.. The interior of my 60 is pretty stock and no tack.
Old Oct 18, 2008 | 07:36 AM
  #42
MINIdave's Avatar
MINIdave
Wow, I can't decide if that's a really tiny car or a really big woman!
Old Oct 18, 2008 | 01:23 PM
  #43
Minimad's Avatar
Minimad
Yes, but it makes me wanna "salute" the Union Jack!
Old Oct 18, 2008 | 02:24 PM
  #44
Capt_bj's Avatar
Capt_bj
Once ya pass alg' 101 call me
Old Oct 18, 2008 | 02:33 PM
  #45
boney's Avatar
boney
capt, not to be rude ot anything, its not called algebra 101 any more its 1010 and 1050. and thanks, I passed just fine
Old Oct 18, 2008 | 06:35 PM
  #46
Mercy's Avatar
Mercy
I found those pics when I was looking for Mini Limousines. I think this is the garage that made this mad mini.
The website on the last image I think is how I eventually came to find the sexy Russian Seems ironic and something that could get you killed in Russia to wear a UK flag!
Old Oct 19, 2008 | 08:33 AM
  #47
dimini's Avatar
dimini
I'm afraid to ask what that rear seat is supposed to be. And that hood graphic. Is it supposed to be whispering to us "Shhhh, this classy love limo is sneaking into a mini meet near you"?
Last edited by dimini; Oct 19, 2008 at 08:37 AM. Reason: brain locked up... Why would anyone build this car?
Old Oct 19, 2008 | 11:58 AM
  #48
second to none's Avatar
second to none
Originally Posted by boney
Hi all, my son and I have just purchased a 1967 mk1 mini. The car seems to be in fairly good shape. The car (as near as I can tell) has had the 850 removed and a 1098 installed.(would i get much more power with the 1275 upgrade?) The power seems fine but is running 4,000 rpms at 65mph. I dont know how to tell what the final drive ratio is without counting the teeth on the gears. Any suggestions on how to figure this out without removing the engine/trans? The car also appears to have 7" front disc brakes. I would like to upgrade them to the 8.5 discs and go to 12 inch wheels. Just would like your input on the pros and cons on this.
For your gear ratio issue, I remember some of the Cooper S models (not the 1275, but either the 997 or 1071) came with really close-ratio gearboxes as you have described. Also your 7.5" discs are from a Cooper S. Maybe your original motor was swapped out for your 850 sometime in its history.
Old Oct 19, 2008 | 06:20 PM
  #49
Mercy's Avatar
Mercy
LOL.. no idea why anyone would build this car There are pics of the build around on the Internet too.. The seat .... .uhhhh I guess you should be thankful there is no tongue sticking out the lips..
Oh yeah.. this is a thread about gear ratios.. sorry Boney
tr3y003
Oct 22, 2015 10:48 AM
Mini'mon
Aug 26, 2015 01:02 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
marendt428
Aug 8, 2015 04:44 AM
PelicanParts.com
Aug 7, 2015 08:39 AM
