Cost of ownership?
Old Sep 27, 2007 | 11:23 AM
Deuce5150's Avatar
Deuce5150
Cost of ownership?
So I was kicking around the idea of buying a classic Mini to take over my daily driver duties. Assuming I find one that is in good shape, what is the cast to operate one on a regular basis? Are parts expensive? Available? Any insight would be very helpful. I'm trying to do as much research as I can before diving in head first. Thanks!
Old Sep 27, 2007 | 11:34 AM
MINIxB's Avatar
MINIxB
Well you gotta remember it's a Classic Mini.... something can and will break on it. Some parts are expensive for it some aren't. You can get most of them on the internet though. I've had my Mini for three months and the water pump and breaks have already gone out on it. LOL. Easy fixes though. They're not hard cars to work on.
Old Sep 27, 2007 | 11:47 AM
ImagoX's Avatar
ImagoX
Check out the parts on http://www.GBcarparts.com, http://www.minimania.com and http://www.7ent.com/ to see what things cost. Like MINIxB said, stuf WILL break, and when it does you'll often have to do work yourself (unless you have access to a family member who's a machanic like she does), but they are easy to work on. You'll need a Haynes Manual for the car (available at Amazon).
The good news is that when they're running, they are AWESOME on gas - I get about 40MPG most weeks on mine, and can go a whole week on a $12 tank of gas. Of course, I don't have a long commute in the morning, but I was going through a tank a week or so on my '06 MCS, and that car cost like 3 times as much to fill...
Old Sep 27, 2007 | 12:54 PM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
If you are going use a Mini as your only car, you'll need to stock up on parts when you get the car. As stated above, a lot of parts are quite reasonable, but if you need the car to get to work, you don't want to have to pay for rush shipping from California/Nevada/England to get back on the road.
Old Sep 27, 2007 | 02:34 PM
Minimad's Avatar
Minimad
May I suggest that if you wish a daily driver you limit your search to a late model, low mileage 90's Mini. They are more refined for daily driving and have modern(ish) features. You may find some with air conditioning. Look for adds such as "79 Mini updated to 98 Specs" or "70/'95 Mini". The only caution being that they do have computers which if they fail may present difficulty in sourcing in the US.
A high end sample:
http://www.minimania.com/web/id/7006...ale_Detail.cfm
a lower price example:
http://www.minimania.com/web/id/6986...ale_Detail.cfm
Otherwise, if you are mechanically inclined you can opt for an older Mini that someone else has gone over. Most classic Mini owners do at least fundamental repairs out of necessity. If you aren't interested in getting into such maintenance issues, buy a new MINI. They're fun.
Old Sep 27, 2007 | 03:43 PM
Big Norm's Avatar
Big Norm
depending on the condition is could cost you reg. maintinence cost, or thousands...........hard question to anwser
Old Sep 27, 2007 | 08:19 PM
Miniranda's Avatar
Miniranda
My Mini has my paychecks spent before they even hit my bank account!
She's cheap to run but then I start buying stuff online. There is always something to fix (exhaust pipe fell off) or something to buy (new front seats) or something to start saving for (disk brakes /1275 engine conversion/Minilite wheels... etc, etc, etc) So when I'm not driving her I stress out about money but as soon as I get in she makes it all better and I start adding items to "the list".
Old Sep 28, 2007 | 07:59 AM
Deuce5150's Avatar
Deuce5150
Thanks for all the help you have given me so far. I actually found one in my area that I am going to look at.
http://madison.craigslist.org/car/424103808.html
What do you think?
Old Sep 28, 2007 | 08:46 AM
Agro's Avatar
Agro
It's hard to tell too much from those low res pictures, but that looks like a nice, late model Mini. Check for rust and oil leaks.
Old Sep 28, 2007 | 02:46 PM
Minimad's Avatar
Minimad
CHECK FOR RUST! Don't worry as much about the mechanical unless the trans is shot or oil pressure is nil....that's the easy part to fix...
From Minimania TEch articles:
[FONT=arial][SIZE=3]Rust and Minis have a great affinity for each other. Sooner or later all owners of non-restored old Minis will have to tackle this problem. This article covers rust detection, prevention and repair.
Rust Detection
When checking a Mini over before purchasing, it is important to check carefully for rust. The diagram below shows the typical rust areas:
Key:
  1. Headlamp surround and bowl (part of front wing). These rust out from behind due to accumulation of road dirt and moisture, usually only in locales where salt is used on ice.
  2. Lower front valance. Often kerbed and hit by stones, and therefore prone to rust where paint is chipped away.
  3. Lower windscreen surround, top of wing, top of a-panel. These areas rust because of the box section inside this area, which accumulates road dirt and water. The rear seam of the bonnet also rusts because of the foam soundproofing it sits in that retains water.
  4. Lower edge of a-panel. Rusts out from the inside.
  5. Roof skin edge/cant rail. A trap for dirt and rain, prone to rust from the outside in as paint wears. Rust is accelerated greatly on Mk1 cars with sound proofing foam inside the cant rail.
  6. Rain channel (Mk1/2 cars). Does not drain properly, by design.
  7. Door lower edge. Rusts due to blocked door drainage holes.
  8. Inner wing/front of sill. Very prone to rust from accumulated road dirt.
  9. Outer/inner sills. Very prone to rust from road dirt/water trapped inside, and paint chips.
  10. Lower edge of body sides. More common where road salt is used.
  11. Rear subframe. A common casualty of inadequate factory rustproofing. The heelboard is also likely to be rusted.
  12. Roof skin/cant rail See 5.
  13. Boot lid. Prone to rust along the bottom edge. The same applies to van/estate rear doors.
  14. Rear panel/rear valance/rear bumper mounting flange and boot floor.
Rust is also common in the floor pan, particularly the front quarters. For those intending to restore a car, patch panels are available for most common rust areas. Rust may also occur where crash damage has been improperly repaired and covered over with filler.
There are two major types of rust. First, "surface rust" or rust that works from the outside of a panel inwards. This rust starts when paint wears or chips away. Depending on environmental conditions (humidity, temperature and use of road salt), this rust may progress at a slow rate and can often be sanded or blasted off. This type of rust is usually found in the roof channels and external body seams, and where the paint has become chipped. This rust can be prevented from developing into a problem if it is sanded out and repainted - if your car has any rust like this, treat it now.
Second is rust that works from the inside out. This is usually characterised by loose rust flakes and bubbles in paint work, and has worked its way to the outside from the other side of the panel, e.g. from the inside of the A-panel to the outside. This type of rust is far worse and is more common in countries that put salt on the roads during winter. The only hope for repair is cutting out the rust and replacing it with new metal.
If a car has rusted to the extent where holes can be found in any of the above locations, heavy-duty repairs are needed. A car with rust in the roof pillars, roof skin, floors, or worse, should be avoided unless it is a collectible model or intended for restoration.
Beware of a car with fresh paintwork. It can take from six months to one year for painted-over rust to bubble out again. Meanwhile, it has been spreading under the paint causing severe problems that may not be detected until it is too late. Stay away from any car with blisters in the paint as it is a sign of hidden problems and poor paint preparation work.
Rust Prevention
If your car body is in good condition, rustproofing it is an effective means of keeping it that way. Minis have until recently been delivered with almost non-existent rustproofing. It is not uncommon to find the insides of sills and other box sections to be bare-metal, having not even received a coat of primer. As the car was assembled before painting, the inside of the door hinges is usually bare metal.
Undersealing the floor and wheel arches is an excellent method of preventing rust. It can be applied professionally, or can be purchased in a form that can be painted or sprayed on. It then dries into a tough, flexible coating. The areas to be undersealed must be absolutely free of rust, or the underseal will allow it to spread while hiding it from observation. Car must be taken not to paint shut any drain channels such as those in the sills.
Box sections, such as the sills and floor cross member can be protected by injecting rust-proofing wax into them. The wax/fluid is applied with a special nozzle designed to reach into enclosed areas through a small opening. For best results the wax is heated to thin it, and after application it sets into a moisture-proof layer.
Small crevices and awkward areas, such as the drain channels in the doors, and the external body seam covers may be protected by applying deodorised fish oil or a similar oil designed for the same purpose. This oil is usually provided in a spray can and has the ability to creep between welded metal flanges to protect otherwise-unreachable areas.
To delay the onset of rust, keep your clean and dry and ensure the underside is regularly cleaned, especially
Rust Repair
The most important principle of rust repair is to catch it as soon as possible. The cost of repair increases dramatically as rust progresses from being superficial to structural.
Superficial rust can be removed by several means. The most convenient is bead/abrasive blasting, which will remove all rust and paint with minimal effort. Providing no holes were revealed, the surface is then ready for rustproofing and painting. Other methods are by hand sanding or machine grinding (use 80 grit sandpaper and finish off with 120 grit to remove visible surface scoring), use of a Sand-n-Strip disc or acid dipping. See the body stripping page for more detail.
The various rust-treating gels and fluids do not give very good results. It is better to remove the rust by abrasive means and then use metal conditioner to prevent rusting, as the rust-treating products are essentially the same as metal-conditioner. If you use them, use the type that dries to a harmless coating rather than the type that must be washed off, as this type is liable to become trapped in body seams from where it can leak out onto your new paintwork.
If your car has surface rust, the time to fix it is NOW. At the least, use a Sand-n-Strip disc, grinder or hand sanding to remove the surface rust. A wire wheel may be used to get into incovenient areas such as the roof gutters. If you do not wish to remove all the rust, or cannot get at it, use POR-15 or similar "Paint over Rust" type paint - use only a recognised brand name as many of these paints do not live up to their claims. At the least, apply metal conditioner and primer, followed by top coat as soon as possible. Even if the results looks ugly, the rust problem is reduced or eliminated. If your car is better than a tatty runabout you may desire a better quality finish, in which case it is best to leave the painting to a professional.
If the rust is more than superficial, it must be cut out and replaced with new metal. Either the entire panel containing the rust should be replaced, or a patch several inches larger in diameter than the rust should be welded in. This ensures that no smaller outcroppings of rust remain in the panel.
Mini body panels such as the wings, sills and front panel, which often rust, are available so cheaply that it is not worthwhile to patch them. Panels are spot welded together; these spot welds must be drilled out for the panel to be removed. A new panel may then be spot or MIG welded in place. If you are paying someone to do the work for you, it will be cheaper to have the panel replaced than patched.
Patching is a skilled art. It is easy to weld a patch into a piece of metal, but very hard to do so without causing welding distortion which is hard to straighten out, especially if gas welding is used. However, it is far more practical than replacing the entire floor pan or a body side. Pre-made patches are available for most common Mini rust-spots.
When repairing the floor and sills, it is possible to remove too much metal causing the body shell to twist. If you intend to remove both outer sills at once, or more than half of the floor pan, the car will need to be jigged or at least have its weight supported by bracing.
[/SIZE][/FONT]
Old Oct 1, 2007 | 09:43 AM
ImagoX's Avatar
ImagoX
... or check the Stickied link at the top of the Classics forum for a Buyer's Guide, complete with a printable check list.
Old Oct 2, 2007 | 05:41 AM
Deuce5150's Avatar
Deuce5150
Thanks. I will give the guy a call and take a look.
minimacattack
Metroplex MINI - Texas
Oct 18, 2016 01:24 PM
vulkandino
Oct 31, 2015 08:29 PM
potterstein
Oct 1, 2015 07:10 AM
aldito2
Sep 30, 2015 10:44 AM
minimacattack
Sep 25, 2015 07:37 PM
