Need to ID a part.
Can you try and check if your windshield washer works? It may well be a washer pump that is remotely installed.
pics from http://www.ukclassicminiparts.com/shopexd.asp?id=408
Do you have Air conditioning? Carb or Multipoint injection?
Though I've never seen it in a mini it may also be an idle-up solenoid (I am not sure if that is the right term for this part)
I know from older japanese cars (carburated) they have an idle-up solenoid valve that is tied to a diaphragm that is connected to the carburator's throttle mechanism. Its purpose is to use vaccum to mechanically "pull" the throttle whenever the AC compressor turns on and increase engine idle rpm.
LordOfTheFlies
10-19-2015 05:02 PM
daviday
09-25-2015 01:31 AM
