3rd Gen FAQs 3rd Gen Common Questions & Answers!
Union Jack Taillights
Old Feb 5, 2022 | 04:08 PM
  #176
Budshark's Avatar
Budshark
I’m unfortunately at a complete loss. Successfully installed the US UJ lights in a 2016 Cooper. Did all the coding and it worked for over a year.
Car went in for a CEL and they flashed the code. Reset the programming. Not a problem. Got home reprogrammed as before and now I’m getting a lighting system error when brakes are applied ONLY when the car is moving above 5mph. In addition to the error, the brights briefly flash.
I’ve looked at BFD which shouldn’t be on in US and tried various settings as that seemed to make sense why the error doesn’t appear when the car is in park to no avail. But now that I know it flashes the brights when this happens I’m even more confused.
Any thoughts?
Edit: I had a chance to walk through the settings. It looks like Bremsl_1_output default changed and I had to set that to off from bl_x. Validated everything else. That setting was apparently throwing the error and the error was making the high beams flash.
One last issue to debug now. When the Hazards are on IF you turn on a blinker the blinker overrides the hazard on the dashboard and exterior lighting. The hazard button remains flashing. If you turn the blinker off, the hazards return to flashing both lights. Not a big issue as very rare condition but will be trying to fix it.
Old Feb 7, 2022 | 12:33 PM
  #177
Weird, something in the code changed?
Old Mar 4, 2022 | 06:08 PM
  #178
Minimaniac69's Avatar
Minimaniac69
Lights won’t lite up
how do I get my lights to lite up when I turn my light on.
I’ve kinda got part of my signal light working and half a break light.
the Union Jack doesn’t light up at all.
im new to BimmerCode and could use some serious help please.
Old Mar 16, 2022 | 10:36 PM
  #179
TechTurbo's Avatar
TechTurbo
First wanted to thank DunkM for the coding guide. I wanted to add that there is a need to add these to the Initial Coding, or you will see flickers even when there is no code thrown.
BFD_x_IS_LED - aktiv
BFD_x_KALTUEBERWACHUNG - nicht_aktiv
BFD_R_WARMUEBERWACHUNG - nicht_aktiv
Also the comment about MAPPING_BREMSL_2_x_OUTPUT was kind of hard to understand... can someone amend / confirm the right values for:
  • US Halogen to US UJ
  • US Halogen to Europe UJ
I assume if one has US LED to begin with, you don't need to worry about updating MAPPING_BLINKEN_2_H_x_OUTPUT nor MAPPING_BREMSL_2_x_OUTPUT?
Last edited by TechTurbo; Mar 16, 2022 at 10:38 PM. Reason: Added 1 coding attribute
Old Apr 17, 2022 | 12:22 PM
  #180
IrishCooper's Avatar
IrishCooper
Originally Posted by bluonyx
So I just installed my UJ Euro taillights and I'm not getting the horizontal amber bar at all. That was the whole main reason I even purchased them.
I have a 2019 JCW with the newer UJ Brake lights and followed the directions in the 1st post.
Anyone have any ideas if there's a seperate line of code for just the horizontal amber line I missed?
This is the same problem im having, did you find a way to make it work?
Old Apr 17, 2022 | 12:49 PM
  #181
IrishCooper
Im having the same problem, did you figure out a solution?
Originally Posted by dubdub
I’m trying to follow DunkM’s post, but I’m not getting the correct result. I welcome any and all suggestions.
I’m in Canada and have a ‘22 F56 base model LCI2 that came with OEM Union Jack tail lights and I’m trying to install the European/UK Union Jack tail lights (with amber turn signals). I can install them but I can’t get them to use the horizontal part of the light. I don’t get any errors at any point in the process, even without any coding.
The result I'm seeing is just the vertical light being used for the turn signal and brake light. The UK lights basically behave like the US lights, just without the horizontal bar. (I've attached videos below.)
The wiring harness has six wires for the connector so I didn't re-pin anything. Should I still re-pin something? What am I missing?
Videos
US lights, stock: https://twitter.com/i/status/1482549462920830981
Euro spec lights, with DunkM's coding: https://twitter.com/i/status/1482549560526491650
Coding
I have tried a few things, restoring from backup before each:
  1. No coding (I don't get any errors)
  2. DunkM's post verbatim (Initial coding + EU specific)
  3. The following
Here's my last attempt, along with the stock/default values, for context:
Parts
US, stock: 63217435135 and 63217435136
EU/UK lights: 63217435133 and 63217435134
Old Apr 17, 2022 | 07:27 PM
  #182
TechTurbo's Avatar
TechTurbo
So we do not overlook the obvious, did you get the Europe instead of the US version? Only the Europe version shows Amber.
Part No: 63217435133; 63217435134
Old Apr 20, 2022 | 10:29 AM
  #183
Yep those are here and noted
https://www.ecstuning.com/Search/Sit...h/63217435133/
Old Apr 20, 2022 | 03:38 PM
  #184
NBCGLX's Avatar
NBCGLX
I'm wondering the same thing. My LCI1 F57 came with the UJ lights, but I've desperately wanted to install the European/UK lights with the amber turn signals since I got the car in May 2018. I won't spend the money on them, however, until I know I can get them working as intended since they aren't exactly inexpensive.
Old Apr 28, 2022 | 08:09 PM
  #185
IrishCooper
Possibly. I went through Bimmercode trying to program them for my 2022 and cant get the amber turn signals to work. I did all the things mentioned in the posts above. My next step is to find a Pinout of the taillight harness and start testing wires with a multimeter.
Old Apr 28, 2022 | 08:11 PM
  #186
IrishCooper
I did not buy OEM tailights I bought aftermarket ones but yes they have the separate Amber turn signal like the European version. I cant imagine the wiring inside is different. Im sure they based it off the same design so the plug would match up.
Old Apr 29, 2022 | 05:36 AM
  #187
michaelo's Avatar
michaelo
Get the aftermarket lights that do not need any programming. Problem solved.
Old Apr 29, 2022 | 07:31 AM
  #188
NBCGLX's Avatar
NBCGLX
That only works if you have a pre-LCI1 car, or an LCI1 car without the factory UJ lights.
Old May 3, 2022 | 04:23 PM
  #189
IrishCooper
Sorry, not problem solved. These cars nowadays are smart, programming is almost always required. In my case it might even be a wiring issue cause the 2022 with the factory UJ lights only has 1 wire that sends the brake and turn indicator signal, and the computer tells it the difference.
Old May 3, 2022 | 05:01 PM
  #190
isugoo's Avatar
isugoo
according to ECS website, Helix version should work with both, LED and Non LED versions.
Old May 3, 2022 | 06:41 PM
  #191
michaelo's Avatar
michaelo
Aftermarket tail lights work perfect on my 2019 Mini Cooper Convertible. No programming - plug & play. I have also seen them on 2021 Mini Coopers with no issues as well. Not sure about a 2023 though.
https://www.ebay.com/itm/36380017845...EAAOSwfbFiVoVA
Old May 4, 2022 | 07:09 AM
  #192
All those taillights we have the info on as we work with the main supplier, watch those reseller on EBAY and amazon as they don know MINIs and mix up models/what they work with and for.
Old May 4, 2022 | 08:36 AM
  #193
NBCGLX's Avatar
NBCGLX
Did your 2019 F57 come with the UJ tail lights from the factory? And if so, to clarify, you installed the pictured aftermarket lights and they function properly (i.e., separate turn signal, brake light is the thin vertical inner piece, and the Union Jack is the running light)?
Old May 4, 2022 | 08:23 PM
  #194
IrishCooper
My question as well.
Old May 4, 2022 | 08:25 PM
  #195
IrishCooper
Are you saying there are ones that work for LCI and different ones that work for non-LCI? It seems to be an issue with those cars that came with Union Jack taillights from the factory like my 2022 F56.
Old May 5, 2022 | 06:56 AM
  #196
Some of them are and some that are sold have a harness that piggybacks so they can work on both. I dont know what ebay/amazon reseller's sells as they don't like to show actual pictures.
Most those sellers copy our pictures on ebay and amazon. My R58 JCW and R52 MINI Convertible are all over ebay and amazon as copied cars and then they overlay the pictures of what they are selling. Once they get turned in for copying our pictures another one pops up. lol
Old May 5, 2022 | 03:02 PM
  #197
IrishCooper
yeah Ive seen that, bad photoshop of the product on a car instead of actual pictures of it installed.
Old May 5, 2022 | 03:22 PM
  #198
TechTurbo's Avatar
TechTurbo
The taillights are such an essential part that I had no hesitation to pay more for OEM. For the UJ I also coded it to always stay on like the front DRL. Consider you can sell your old taillight on eBay for $100 or more, just get the factory light.
Old May 5, 2022 | 03:42 PM
  #199
isugoo's Avatar
isugoo
Can you please confirm which one works for both, pre UJ and post UJ tail lights? From my digging on your site, Helix was the only one clearly stated to work on both tail lights without coding.
Old May 5, 2022 | 07:12 PM
  #200
IrishCooper
Well at first my main interest was in getting the separate Amber turn signal but I also love the way the smoked clear tails look, over the all red factory lights.
