3rd Gen FAQs 3rd Gen Common Questions & Answers!
How to change cabin air filter
Old Jan 8, 2018 | 12:08 PM
vetsvette's Avatar
vetsvette
Moderator
Found this on another forum.
Here is the basic procedure and some photos. ~10 minute job.
Tools needed: Flashlight, Torx head screwdriver with T-20 bit, towel or knee pads.
Parts needed: New filter set - there are two types, one is carbon activated and costs more but it reduces odors.
1) Open passenger door, kneel on ground and find/remove one T-20 screw up high on the center console side panel. Photo 0645 shows location.
2) Carefully pull the side panel away from the center console starting at the bottom and moving counter-clockwise. Once the panel feels loose, pull it straight back toward the seat, (the end closest to the firewall fits into two slots). There is a small light attached to the panel. I did not disconnect it but doing so and getting the panel completely out of the way may help you. Once removed, you can see the filter door with the X-shaped reinforcements all the way forward - snap clip on LH side, hinge on RH side. See photo 0640.
3) Open the door, then remove it by gently moving it up and down until the hinge disconnects from the air conditioning unit. See photos 0642 and 0644. Note the air flow direction shown on the filters - front to back.
4) Pull out the upper filter and then the lower one. You'll need to lift the lower on up then pull it out. Inspect and replace as necessary. See photo 0643. If you have a small wand attachment, there may be some value in attempting to vacuum out any leaves/debris that may have collected in the bottom of the chamber, but be careful not to damage the cooling fins that are on the heat exchanger just rearward of those filters!
5) Reassembly is the opposite of removal. Again, make sure you orient the filters correctly. Make sure the wire bundle that routes low on the unit is clear of where the panel clips will go otherwise you may damage them.
Cheers!
Attached Thumbnails How to change cabin air filter-fullsizeoutput_4cd.jpeg   How to change cabin air filter-fullsizeoutput_4ce.jpeg   How to change cabin air filter-fullsizeoutput_4cf.jpeg   How to change cabin air filter-fullsizeoutput_4d0.jpeg   How to change cabin air filter-fullsizeoutput_4d1.jpeg
Old Jan 31, 2018 | 06:08 PM
Rick369's Avatar
Rick369
There are actually 2 filters? Do you have any idea why it is designed this way? Every car that I have owned has had only 1 cabin air filter.
Yep. Two filters
Old Feb 20, 2018 | 05:39 AM
Yep, 2 filters. The newer BMWs share the same filter set up, so my guess is they just designed the airboxes on a similar platform.
Old Feb 13, 2019 | 01:34 PM
detours's Avatar
detours
Extra step for optional footwell light panel
When I went to change the cabin filters in my 2016 F54 Clubman S, I had to remove an additional footwell panel to gain access. The panel has some ducting and an LED light.
Optional footwell lighting and air duct
  1. To remove the footwell panel, locate the two T10 torx screws near the glove box door. The panel will drop as you unscrew them.
  2. Slide the panel toward the passenger seat.
  3. Unsnap the LED wiring connector.
  4. Set panel aside.
Reverse steps to replace the footwell panel.
Footwell panel screw
Old Feb 13, 2019 | 01:57 PM
Thanks for the info
Old Mar 31, 2019 | 08:30 AM
jma's Avatar
jma
Thank you vetsvette for the info and pics.
Mini could not have placed those filters in a more inaccessible spot if they tried...
In my case even more difficult because I couldn't open the flap door all the way, or maybe I missed something.
Anyway, the filthy ones came out and new ones went in. I had just bought the car, a 2016 Clubman with 15k miles, no way those filters had ever been cahnged.
Old Mar 31, 2019 | 09:22 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
For F56 I see four different part numbers. I know they went through all sorts of issues with odors, which is the current correct filter part number?
Old Mar 31, 2019 | 09:31 AM
jma's Avatar
jma
This is what I used:
https://www.amazon.com/gp/product/B07N1HKGVQ/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B07N1HKGVQ/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
My car is 2016 Clubman base, production date 11/30/2015, hope this helps.
Old Apr 1, 2019 | 07:50 AM
64116823725 looks like the lastest part by MINI the superseded the old parts, you can still get the older part number for an aftermarket
Old Apr 1, 2019 | 08:05 AM
Minnie.the.Moocher
If you enter that number into realoem you get 64316835405 , hence the confusion. Am I reading correctly?
Old Apr 1, 2019 | 08:14 AM
Your right, sorry about that. Looks like there was a split year update on 2/2016 on the housing itself. They supered the parts number for the old housing to the newer housing. We can order in the new filter and place them side by side and figure this out. Most of the time its just a revision with no actual part change.
Old Apr 6, 2019 | 03:06 PM
Minnie.the.Moocher
The filter that came out of my car had the blobs of hot glue on the bottom. Not sure if they still do this when installing new filters or has the newer part corrected the issue.
Did they purposely put the opening in the hardest to reach spot?
edit - found this on newtis.info
Bottom microfilter has three spacers (1).
The bottom spacers (1) need to be inside the heating and air-conditioning unit.
Note:
As of version 2/2016, the spacers (1) are omitted.
Old Apr 8, 2019 | 08:05 AM
Yep, we just got them in, exactly the same size and everything except the ~725 version: https://www.ecstuning.com/b-genuine-...116823725~oem/
It has that extra 3 blobs of hardened glue only on the one filter. Must have been for seating purposes. They come right off also with a quick peal.
Old Jun 1, 2019 | 10:27 AM
LiL Stinker's Avatar
LiL Stinker
Thanks for the instructions on where these are and how to get them out. Brought my wife a dealer CPO 2018 with 9k with full warranty. I’m changing out the filters with K&Ns been real happy with there products in all my pass MINIs. 8 and counting.
Old Jun 27, 2019 | 09:58 PM
jvanbrecht's Avatar
jvanbrecht
I just replaced mine with K&N reusable (washable) filters. I swear.. they must have midgets design the car.. you have to be tiny and a contortionist to replace the damn filters.
As for why it is two filters. Well, the smaller cars get, they still need all the same systems, they just have to get innovative in how they pack them into the cars. To maintain a set surface area for the airflow in an area where you cannot have a full size filter, you have to break it into two to install them.
At least that is my guess.. Or what I tell myself as I was swearing trying to get the old filters out.
Old Oct 27, 2019 | 06:40 AM
SavannahMan's Avatar
SavannahMan
I have a 2019 MCS Convertible. I’ve always changed filters on my other brands but after reading this post I have to ask, is this filter change a task for the average DIYer or better left to the pros? I wonder if even independent BMW / MINI shops would already be familiar with the quirks of the ‘19 model.
Old Jun 21, 2020 | 09:00 AM
Goodrat's Avatar
Goodrat
Bottom spacers
People are pointing out the spacers on the original bottom filter, but not saying if they are required.
For my 2014 Cooper S the original has the spacers but I installed "PG Cabin Air Filter PC9976" from Amazon without those spacers.
Old Jun 22, 2020 | 01:26 PM
its did not move or rattle in the housing?
Old Jun 23, 2020 | 05:41 AM
Walt's Avatar
Walt
I thought the spacers were there to prevent the filter from wicking up any moister/condensation that might accumulate at the bottom of the housing?
Maybe its both?
Old May 20, 2022 | 11:01 AM
Llanrhaeadr_Cymru's Avatar
Llanrhaeadr_Cymru
I’m trying to change the cabin filter on my 2021 F56S and I’m unable to locate the door to the filters. What I’m seeing behind the panel does not look like the pictures in this thread. Did MINI change the location of the filters? Any help in this regard would be helpful.
Old May 20, 2022 | 02:08 PM
Take a picture and post up. I have not looked at the 21 and 22'
Old May 21, 2022 | 05:11 AM
NBCGLX's Avatar
NBCGLX
I just recently changed the filters on my 2019 F57. I had to remove the panel that sits below the glovebox, but other than that the procedure was the same as posted above.
Old May 22, 2022 | 09:57 AM
Llanrhaeadr_Cymru
Thank you! I did finally find the hatch as pictured earlier, and as described needed to hone my contortionist skills to see it.
Old May 22, 2022 | 10:02 AM
Llanrhaeadr_Cymru
Thanks, I may need to try that approach as well. Currently I can only get one filter into the slot. The original filters did not have the “blob”. Right now this one is installed in the bottom, so I’m going to remove it and the blobs and reinstall to see if that gives me room for two stacked filters. If not, the panel just behind the glove compartment (as you mentioned) will need to come off. I agree with an earlier posting about being a contortionist to replace the filters and also might add having a small to medium build to work your way under the dash.
Old May 26, 2022 | 07:33 AM
cjv2's Avatar
cjv2
FWIW:
- My 2017 F56S does not have the panel behind the glove box in order to remove it. Some research turned up that, on spec, it never had one. Just not part of the 2017 F56S, period. My guess is that it was added to the F56 when they rejiggered it (LCI introduction, years later). When I was replacing my cabin air filters I noticed this. I was also pretty positive that if had that panel been there, I would have had to remove it to get the filter change done.
- I also noted (while trying to figure out the differences between various MANN filters) that the spacers ("blobs") definitely were removed from spec at some point -- I would similarly guess at the LCI introduction, pointing to a more general change in the setup. Now, I can't prove that, but all of it would point in the direction of the '21 and '22 being a little different than the older F56 instructions and guides flying around -- the panel for sure, and the spacer question maybe being more important -- as compared to my 2017 (that was actually manufactured in late 2016).
Hope this is useful.
