2nd Gen FAQs 2nd Gen Common Questions & Answers!
What's the best oil / oil change interval?
Old Sep 25, 2017 | 10:01 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
This is one of those topics that make long time forum members think "Oh no! Not another oil thread!"
There are some that are obsessive-compulsive about their oil changes and intervals, and some that are not. Some (admittedly anecdotal) data follows, and some personal opinion as well.
MINI originally set the oil change interval for the Gen2 cars at 15,000 miles. That led to a lot of problems, especially with the N14 engines - clogged VANOS actuators, engine damage due to low oil, etc. etc. Eventually the interval was changed to 10K. In the first three years of included maintenance, dealers will typically change the oil at 8,000 miles or greater since the last change.
Here is a list of LL-01 and LL-04 oils:
Castrol Edge 5-30 LL-04
Castrol Edge 0-30 LL-01
Mobil 1 SAE 0-40 (apparently no longer meets LL-01)
Penzoil Platinum European Ultra SAE 5-30 LL-01, LL-04
Valvoline SynPower SAE5-30 (can't find any BMW ratings)
Shell Helix Ultra 5-30, BMW LL-01; API SL/CF; ACEA A3/B3, A3/B4;
Oil Filter
Which oil filter to use is another big debate, some say MINI only, others scoff at paying extra. Tthere's a thread here: https://www.northamericanmotoring.co...il-filter.html
The MINI branded filter appears to be the Purflux L358A, higher price if the box says MINI/BMW.
What's the best oil change interval?
Personal opinion follows:
I have always been a 5,000 mile interval guy. I think at 3,000 miles as recommended by the oil change places you are throwing money away. I try to keep it to 5,000 miles, maybe 7,500 at a stretch. There are people who send oil samples to a lab for testing, and there's data to suggest that with a high quality oil you're good to 10,000 miles. OK, I'm an engineer and I can appreciate data. I also appreciate the value of adequate "design margin", or being conservative so you don't have to worry about being close to the edge. Since I only drive 10,000 - 12,000 miles a year and do my own oil changes, I figure that doing oil changes at 5,000 mile intervals is good insurance and preventative maintenance for relatively small cost. I'm at 72,000 miles on my 2012 R56S with no engine issues. I have an Acura MDX that is 15 years old and nearing 300,000 miles, it has always had 5,000 mile oil changes and still runs perfectly so that's my proof point. (Or maybe it just means that Honda/Acura built a great engine.) Anyway, the summary of the experience of owners on NAM seems to be to keep the oil change interval to 10,000 miles at most, with 5,000 miles being preferred. Frequent checks of oil level in-between changes is mandatory for N14 engines as they tend to burn a lot of oil, with disastrous consequences if it gets too low.
What's the best oil?
There are probably as many opinions on this as there are forum members. Some swear by a particular brand / weight of oil, saying that mileage improves, oil consumption decreases, performance is better, hair loss is reversed, and they're more attractive to members of the opposite sex when they use brand X . OK I'm exaggerating for comic effect Personally, I stick to Castrol Syntec European Formula 0-40, or Mobil1 0-40. Arguably it is overkill, MINI specs 5-30 oil. See my comment above about design margin. MINI also specs their long life LL-01 rating, however if you are changing oil every 5K this really doesn't matter so long as you are using a high quality synthetic oil.
That's my personal opinion, and it has worked for me (so far).
Old Sep 25, 2017 | 10:52 PM
cornjuice's Avatar
cornjuice
I have zero experience with Mini engines up until a week ago when I bought my first. I do have 15yrs with Subaru motors and e85. It has taught me a lot about oil. Couple of key points specifically which relate to your post:
*heat cycles: how many times an oil has reached high/peak temps
*driving conditions during mileage: city, mountains, dusty back road?
*fuel: what, how much (directly related to the above and has effect on how soon oil needs to be changed before sheering)
for me..if I have hit my 'max' on 2 of the above 3.. I change my oil.
I consider a redline session or high heat cycle to take roughly 1k miles off my oil (changes normally at 5k). I consider 15 tanks of 91oct a max at normal driving before a full oil change & anytime I drive to Tahoe and back (for example) I take 1k miles off too.
*I also use oil which I have tested before in +20psi fa20 setup. Blackstone has a really comprehensive test if you purchase the sample kit. I learned that running pump gas (91oct here) under normal->spirited driving ..Pennzoil platinum 5w30 was good for 7k miles. Running a 30% e85 blend and the same oil tested ~same level of detergents at just over 5k. On a stock 2014 wrx [ej255] results were very similar. For reference - the oil still retained more than 70% of its detergents, as tested; summertime 105f ambient, 7k miles normal daily driving..with a few romps to redline.
Oil is life. Love it..your engine will love you. I'm saving for gauges on my JCW for this reason. I want to track max and average oil temp and pressure..as well as boost and other essentials. With that..i may be able to safely stretch my oil a bit further..but not until then.
Old Sep 26, 2017 | 05:49 AM
AnOldBiker's Avatar
AnOldBiker
4th Gear - An Official NAM Greeter
The closest I've come to foreign engines are the Japaneese ones. I had a Toyota pickup for 13 years and put 400k on it before giving it to the neighbor kid when i retired. Changed with full sync oil / filter every 7.5k and never had the heads off. He had it for 80k and sold it when he had enough to buy a new car.
I have a Dodge 4x4 with a Cummins and installed an oil bypass system when new, send in a sample every year to BlackStone and wait until they said I was near the outside of the perimeters and change the oil. Main filter is changed every 5k, and the bypass changed every 10k. This last run has 60k on the oil and still within perimeters. (engineers calculate the bypass oil filters the oil 10 times per running hour through a 2 micron filter)
Oil actually never breaks down, but the additives will. This is what causes all the problems with engines/engine oils. Oil companies would recycle the oil, (and have in the past) but the cost is prohibiting. It's more cost effective for them to just refine new. I do know if they could have an economical way to reprocess, they would. I retired from an oil refinery and they have/do look for ways over the last several decades. Once it's extremely hard to find and extract crude oil, they will be in a financial pinch, and they know it.
But as 'cornjuice' mentioned about, I'm a bit longer in owning a Mini than he, but by 2 1/2 weeks. So I'm in AWE as to the way Mini does their oils. Way different than I've been use to.
My mini says I'm to use 0w-20 with LL-14 fe+ oil. Way different animal than I'm use to, but intend to use until warrantee is over. But per the owners manual. I can use almost every grade listed in the free market if I can't find 0w-20, as long as it's in the LL-14 fe+ ratings.
And the discussions of other Mini owners using 5w-30, 5w-40 and every number with in the oil rating world, foreign and domestic .. seems martian to me ... when the engine designers usually require a specific grade/rating of oil unless major modification is done.
So I'm subscribing to this thread to see what others are thinking and doing ... if it doesn't add to my confusion.
Old Sep 28, 2017 | 10:34 AM
Dr. Spade's Avatar
Dr. Spade
Oils I've used
Mobil 1 5W-30. Changed at 5,000 miles. Burns quickly. I'll go thru all 5 quarts and be low again
Valvoline 5W-30. Changed at 5,000 miles. Burns nearly as quick as Mobil 1.
Pennzoil synthetic 5W-30. Changed at 6,000 miles. Burns less quickly.
Castrol Edge 5W-30. Also burns less quickly. Changed at 6,000 miles.
Pentosin 5W-40. Noticeably less burning. Still on my first round of this at 4,000 miles.
N14 R56 Cooper S 6-speed. Manic Stage 3 autocross and weekend track day car.
Old Oct 2, 2017 | 05:17 PM
thebombardier's Avatar
thebombardier
I'm on the 5000 mile interval. Mainly use Redline as it's the only synthetic I can get locally that is API Group V and certified BMW LL-04. I'll burn through nearly 2 qts before i change my oil though.
Old Oct 3, 2017 | 10:58 AM
ke3ee's Avatar
ke3ee
I currently own 2 R60s. a 2012 with 75k and a 2016 with 18k. Ive changed the oil at 5k on both cars. I have used Castrol Edge 5w-30 in the 2012 ever since new with either an OEM or K&N filter. On the 2016 its been changed 3 times total , once at the dealer. When I changed it, I used K&N filters and Liqui Moly 5w-30.
I think the thread starter stated it well, don't go to the design limits. Ive always believed that while the oil doesn't breakdown it does carry more and more dirt, fine particles etc.. and the little filters can only hold or filter so much for so long.
$45 every 5k to me is good insurance, I read about failed timing chain tensioners, failed Vanos and have to think that dirt and sludge play a part in those failures.
Old Oct 3, 2017 | 01:17 PM
F56-JCDub's Avatar
F56-JCDub
I have been using AMSOIL for years on Dodges, Jeeps, and Land Rovers. This is my first MINI, and I plan on using AMSOIL as well.
When I first started using their oil, I was changing oil at 6,000-mile intervals. Then I started using BlackStone Labs for oil analysis and found that the AMSOIL in the engine had plenty more life in it and extended intervals to 10,000 - 12,000 miles. I continued with oil analysis and found I that I was at about the right interval for my driving and maintenance styles. No engine problems, excessive wear, etc.
Old Apr 3, 2018 | 07:17 PM
minidd99's Avatar
minidd99
I have been driving a Gen 1 R53 for 12 years and I use Castrol Syntec 5-30 and change my oil every 6000 kms or once a year which ever comes 1st. 134,000 kms no problems with this formula for me.
Old Apr 12, 2018 | 12:04 PM
Alpha Motoring's Avatar
Alpha Motoring
Motul 300V 5W30, every 3-4k with OEM filter on both N14 and N18 cars, zero issues.
Old Apr 12, 2018 | 01:50 PM
vetsvette's Avatar
vetsvette
Moderator
Mini changed from 5W-30 to 0W-20 in mid model. They now recommend the latter, but I still have the 5W-30 sticker under my hood. I think the only reason they changed was to squeeze a little better mileage from the cars. Probably more of a bureaucratic decision than an engineering one. I see no reason not to stick with Mobil1 0W-40 and my usual 5-7K mile change. That oil and interval worked well in my R56 for 135K miles and so far on my F56 with 31K. I let the dealership use their oil every 10K and do my own change at 5. When I run out of "free" oil changes the car will not see any more 0W-20.
Old Apr 13, 2018 | 04:42 PM
Big Jim Swade's Avatar
Big Jim Swade
I run 0w-40 in all my cars and a 5k mile change interval. I was using Mobil 1, but changed to Castrol Edge when M1 no longer met the BMW LL rating.
Old May 6, 2018 | 07:12 PM
Doug1066's Avatar
Doug1066
I run Castrol Edge 5w-30 Extended Performance in my 08 Clubman with the N12 engine. I change the oil and filter every 5,000 miles. No issues.
Old May 7, 2018 | 01:51 PM
BluGnat's Avatar
BluGnat
Does anyone use/endorse Valvoline? We have one right around the corner that we've used for years for our Jeeps, and they're great; I see that they do have LL-04 oil...so hopefully this is an acceptable option?
Old May 16, 2018 | 02:17 PM
Max Schrank's Avatar
Max Schrank
My mechanic uses Valvoline synthetic and thinks it is the best overall oil for Minis
Old Jun 1, 2018 | 07:03 AM
Is that link in the initial post working, clicked it and says a dead link?
Old Jun 1, 2018 | 02:13 PM
antjeon's Avatar
antjeon
Hi Guys!
First, I want to thank all of you for putting the time and effort into helping us newcomers to the Mini culture!
Question and advice: I recently bought a 2011 Clubman S with 41k miles on it and performed an oil change about two weeks ago but, I changed it with a Mobil 1 Full Synthetic 5w-30.
1. How soon would you advise on me changing it to a Mini recommended oil?
2. I am considering switching it to Mobil 1 0w-40 or Castrol 0w-30. Can anyone who is/was using one or the other tell me what is the pros and cons and why they chose one over the other?
I ask this because, while I would like to use OEM oil or closest to it (Castrol 0w-30), getting them is difficult! However, most places around me carry Mobil 1 0w-40, and that is one of the reasons why I am considering it.
Thanks in advance,
Tony
Old Jun 2, 2018 | 02:49 PM
antjeon's Avatar
antjeon
Hey guys,
Sorry, it looks like I got trapped into the OIL thread "twilight zone!" lol...
Ignore my last post. After earnestly looking through this thread and multiple others, it appears that there are a few folks out there using Mobil 1 5w-30 and have had no issues. So for that scenario, I will keep the M1 5w-30 for now and change it out in 3k miles and then be switching to Mobil 1 0w-40 and at 6.5k miles interval, thereafter. (Choosing Mobil 1 0w-40 because they are very easy to get around hear, while the nearest place to get Castrol 0w-30 is about an hour away, on a good day! :(
Take it easy,
Tony
Old Jun 4, 2018 | 01:04 PM
MiniSJCW's Avatar
MiniSJCW
I just changed the oil from whatever the Mini dealer had been using to Royal Purple 5w-30. I have a 2013 S with the JCW Engine Tuning kit with 23k miles. So far the only difference is that the engine runs quieter. I felt the oil that Mini used turned dirty very quickly and I don’t ride dusty roads.
It’s also been suggested that I install a baffled oil catch can. ECS Advised me that they don’t have one that fits my car. The search continues.
Thought I’d add my story to this thread.
Old Jun 11, 2018 | 01:18 PM
We have universal ECS Catch cans that will need to be piped to fit but will work, aftermarket there are a couple. You have an S, just select and S in the drop down, its under emissions > engine, then you will see M7, BSH, NM engineering, and ours in a 6 or 8oz version.
Old Jul 31, 2018 | 05:54 PM
Jorge Perez's Avatar
Jorge Perez
I just had LiquiMoly 5w30 with the LL01 spec. It sucked I blew out more blue smoke with it. I had better luck with Mobil 1 0w40 euro, it doesnt LL01 but meets the a3/b4 or w/e it is, and I didn't notice any smoke when I had that in her.
Old Aug 1, 2018 | 11:18 AM
Subw00er's Avatar
Subw00er
A race car friend just told me about Schaeffer supreme 9000 full synthetic. I was thinking about trying it. He has several race engines that use it and he has done tear downs where the mechanic asked him which oil he was using because he should have seen a lot more wear at the mileage.
I'm running mobil1 5w30 full synthetic now.
Old Aug 6, 2018 | 09:47 PM
blue al's Avatar
blue al
I've noticed with the manic map booth coolant and oil run cooler,
would anyone run thinner oil on this basis, (or at least stick to oem grades)
I know most people have opted to run thicker for modified cars
but this has started me thinking is this really the best approach ...?
Old Sep 7, 2018 | 06:33 PM
mbwicz's Avatar
mbwicz
It may sound lazy, but I use 5k oil change intervals because its easy to remember. I rotate tires, check brakes, and change oil and filter at 5000 miles. Blackstone testing has shown that the oil is fine at that interval, but once or twice they made a comment that the filter was 'used up' in my 08 with 120k miles after 5k miles. This was because of the particulates. I've always used MINI filters and generally 5w30 oil. Blackstone testing is $28 and good peace of mind for me.
Both of my N18 engines have used zero oil at 5k changes, my N14 would use about 2 quarts over that interval. I'm now using redline 5w30 ($48/gallon at amazon). Redline used to be preferred by the race team I helped out, and I haven't heard negative reviews on that oil (seems like there is always someone who hates some oil at one time or another). So I'm closer to $90 with my oil, OEM filter, and testing for every oil change. Attached is a copy of a Blackstone report, in case anyone has not seen them before.
I use penzoil synthetic in the non-MINI cars in my household because of the price point and availability. And I don't love them like the MINI.
Just another opinion.
Have fun,
Mike
File Type: pdf
Old Sep 8, 2018 | 07:34 AM
cristo's Avatar
cristo
Alliance Member
My thoughts are 5K miles for turbo engines
and 7.5k for normally aspirated.
Used to use 0W40 euro formula Mobil 1 and
now use 0W40 euro formula Amsoil.
Most if not all of the oils mentioned in this thread
should be fine at these intervals.
Old Sep 8, 2018 | 02:06 PM
Shiner's Avatar
Shiner
For those that are a fan of using AMSOIL, there is a preferred customer discount of 25% that is available. If I purchase a few gallons of 5/30 signature oil that is a huge savings along with free shipping.
