2nd Gen FAQs 2nd Gen Common Questions & Answers!
What's the best oil / oil change interval?
Old Apr 13, 2021 | 04:00 AM
  #76
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Oil flavor preferences are an emotional response and are useless until you get an oil analysis performed. An oil analysis, such as you would get from Blackstone labs, will tell you everything you would want to know about the oil in your engine. If you think 5000 mile oil changes are good enough, or if you drive so little you wonder if once a year is good, get a sample tested from your next two oil changes. Blackstone will tell you if you can go longer or not, AND they can tell you if your engine is wearing between changes.
Also, any oil company will tell you that their product is best...
Old Apr 13, 2021 | 04:41 AM
  #77
Jason Cornelius's Avatar
Jason Cornelius
This guy will not put one more drop of castrol edge in his mini. I burn more castrol than I do liqui moly. No blackstone analysis here, just real world experience. I’m under the hood enough, especially when heading to the Dragon, to know on these 2. I have finally got rid of the burnt oil smell from my last dragon run at the beginning of March, yes it was castrol edge.
Old Apr 13, 2021 | 09:35 AM
  #78
930 Engineering's Avatar
930 Engineering
I would certainly have used RL at least once if I wouldn't live in Europe, where RL uses to be much more costly compared to the US. RL is almost double the price of Ravenol REP over here, which comes with similar quality base oils and some fancy Vanderbilt W-324 add pack plus LL-04 approval. With this approval I can even take it to the dealer and have them perform the oil change. Keep in mind EU fuel is low sulphur, which translates to being fine with C3 (mid-SAPS) oils. LL-04 2018 is the more demanding spec compared to L-01 (which has been updated in 2018 also).
As stated earlier RL's new line of approved oils isn't the same quality as their traditional fully synthetic (PAO & POE based) oils. These oils are based on HC, similar to the vast majority of 'fake synthetic' stuff you can buy. I don't doubt they still perform sufficiently and most won't notice much if any of a difference. This begs the question, why paying more for RL over say Mobil 1 ESP?
Old Apr 13, 2021 | 10:09 AM
  #79
Eddie07S's Avatar
Eddie07S
I haven’t tried the new RL’s oils, but I did notice that they were less expensive than their other oils. If it is more cheaply made, then I would not bother trying it. I will also admit that RL is more expensive than what I care to pay, especially when I find the Motul to be almost as good in performance to my ear... Whereas, I find the Mobil 1 to be what I think is a lower quality. Again, I have no proof of this difference, just opinion. However, with track use the R56 cooks the oil. The ECU oil temperature reading hovers around 250 degF, which is really high. So I am concerned about what I use for oil and will spend the extra for what I think is good oil. With almost 70k miles on the car, this philosophy seems to be working for me.
As for the LL oils that BMW requires, when I looked at the LL spec in comparison to an otherwise comparable non-LL spec, I found no difference. Maybe I missed something, but if that is the case, then I would think that there no reason to use a LL spec oil if oil changes are going to be made every 5000 miles.
Old Apr 14, 2021 | 10:37 AM
  #80
thefarside's Avatar
thefarside
Talking
Originally Posted by minidd99
Does anyone know if engine oil has an expiry date, I have 2 jugs of unused 2 year old oil.
It is fully synthetic Pennzoil
Please do not use this old oil!
Ship it to me and I'll test for free:
Old Apr 23, 2021 | 11:27 AM
  #81
Eddie07S's Avatar
Eddie07S
For what it is worth, here is a link to a BimmerWorld technical article about oils, including BMW spec oil requirements. It appears to be pretty definitive discussion about oils and summarizes the specs, requirements and explains the oil related acronyms.
Old Apr 30, 2021 | 05:08 PM
  #82
930 Engineering
Originally Posted by bimmerworld.com
BMW never certified LL-04 for the US market because a) there weren't many Diesels for sale here, b) it was incompatible with the high amounts of sulfur and Ethanol in US gasoline. However, since 2014 our gasoline more closely matches European sulfur levels. US sulfur remains higher so if you're using a LL-04 oil you should change it more often as sulfur will dilute the oil (5,000 oil change interval should be sufficient). Oil analysis can give you more insight how your local fuel is interacting with the oil. LL-04 and LL-01 are interchangeable/compatible but LL-04 is preferred for BMW turbo engines for its higher ZDDP and low SAPS. Food for thought: the official BMW Motorsport oil recommendation for the M4 GT4 race car is a LL-04 spec oil. Our race team uses Red Line Euro Series 5W40.
SoCalHeli
R55 :: Clubman Talk (2008+)
42
Sep 30, 2010 10:45 AM
koitus
Dec 3, 2009 05:54 PM
npalao
Jun 11, 2008 05:38 AM
boognish
Sep 17, 2004 06:01 AM
Bmuelle
Oct 10, 2002 05:04 PM
