R60 Advice on lowering
Old Aug 12, 2020 | 09:44 AM
  #26
dmath's Avatar
dmath
Originally Posted by CakeEater
How does it handle with the KW V2s?
I think it's great. I lowered it 1.5" and am very happy with the stance. Just before putting the V2s on, I installed an NM rear sway bar. The combination of the coilovers and sway bar dramatically improve the handling. Much more kart-like now. I can take corners at high speeds with no understeer.
The ride is firm but not at all harsh. As suggested by KW, I set the adjustment at 9 clicks from full firm.
Old Aug 12, 2020 | 02:01 PM
  #27
Boogers's Avatar
Boogers
I understand that when the rear gets lowered, camber will need to be adjusted. I'm reading different things as to how best to fix this. Some seems to use control arms but I also see camber arms. What is the difference and what is needed? Thanks in advance, any input is greatly appreciated.
Old Aug 12, 2020 | 03:01 PM
  #28
dmath's Avatar
dmath
Adjustable control arms and camber arms are, I believe, two different names for the same thing. HSport arms are popular. I went with SPC because I like the look and the reviews are good.
Old May 20, 2022 | 02:59 PM
  #29
StormCooperR60's Avatar
StormCooperR60
Digging this up from the grave -
Just recently lowered my R60 on coilovers to right about a half inch fender gap all around and I feel like I’m getting some minor rear axle bind upon acceleration at 50mph and up. No alignment yet and ordered some adjustable LCAs hoping to alleviate any binding once adjusted. This seems to be a hit or miss hiccup on lowered R60s, anyone have any suggestions on the matter?
Old Aug 3, 2022 | 07:16 AM
  #30
cape97's Avatar
cape97
Originally Posted by MarioKart
I’m on Megan CO’s with NM camber arms
Countyman JCW 330hp 19” wheels
Mario
mQubrd Motorsport RPM Power Tuning
So dope! How's the ride on the Megans? also what's the wheel specs you're running?
Old Aug 3, 2022 | 08:01 AM
  #31
MarioKart's Avatar
MarioKart
Vendor
ride is great, BC coilovers are also good
wheels 19x8 et 45 245/35/19 Fenders had to be trimmed once lowered 50mm
MINi ECU Tuning
mQubed Motorsport
MarioPalza@gmail.com
Mario
Old Feb 21, 2024 | 06:37 PM
  #32
jc4real's Avatar
jc4real
Thumbs up Mini R60 V2
Wow! I just bought the V2 for my R60 as well. I wonder what adjustable end link you used. I saw M7 Speeding has heavy-duty adjustable end link, but the range is from 175mm all the way to 350mm, depending on which section you pick. I'm planning on lowering the car by 1in(the min). Thank you!
Originally Posted by dmath
Can't speak specifically to the V3s but I installed KW V2s on my car and the existing mounts work fine. I replaced the front mounts since I was replacing most of the hardware but the new ones I installed were the same as the old ones.
I just realized that I never posted photos in this thread after I did the installation.
Old Feb 21, 2024 | 06:41 PM
  #33
jc4real's Avatar
jc4real
Thumbs up
330HP is insane! I wonder whether you had any modifications on the transmission, like an upgrade to clutch and flywheels to make sure the transmission endures the extra power. I'm trying to do some tunings with my R60 as well(intake, intercooler, etc), but afraid that adding more hp will break the transmission apart. Thanks!
Mario
Old Feb 22, 2024 | 06:11 PM
  #34
dmath's Avatar
dmath
Sorry, I didn't use adjustable end links -- stuck with stock.
Old Feb 22, 2024 | 07:10 PM
  #35
jc4real's Avatar
jc4real
Smile
So the stock endlink fits the KW V2 even after you lower the car for 1.5''? If it works for me as well by the time I install it next week, it will be great. 300 bucks saved from buying adjustabel endlink!
Old Feb 28, 2024 | 08:11 AM
  #36
CaptSlow's Avatar
CaptSlow
I dropped $1,000 on a Godspeed MMX3540-A MAXX set of coilovers and no matter how much adjusting I did, they made the car so much worse. Then I bought H&R lowering springs (28923-1) and out those on the stock struts, and the car is fantastic. Others have said they make the car ride harsher than the stock springs, but I don't notice a difference. The H&Rs lower the car about 1-1/2" at each corner, which is noticeable but not extreme.
spearmin
R61 :: Paceman Talk
Sep 15, 2019 06:44 AM
spearmin
Feb 28, 2017 09:21 AM
gyager22
Jul 22, 2013 06:00 AM
shawnf711
Suspension
Aug 24, 2010 08:06 PM
burley
Suspension
14
Jun 4, 2010 04:45 PM
