R60 Taking panel off over battery
Old Jan 30, 2019 | 01:47 PM
LittleRed2014's Avatar
LittleRed2014
My battery indicator light came on a few days ago and then my 2014 Countryman started to seem like it was powering down in idle. The tachometer goes under 1000. I took the car to the dealership and they wanted to replace the alternator and the battery. The car only has 49,000 miles on it so a new alternator seems like a big fix. I went in to a second shop for another opinion and they said a new battery should fix it. However, the mechanics couldn’t pull the larger panel off. Is that generally hard to pull off? Also, do I really need a new alternator to fix my idle issue?
Old Jan 30, 2019 | 02:49 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Old Jan 30, 2019 | 06:31 PM
mikey_t's Avatar
mikey_t
Probably. MINI batteries tend to have a short lifespan. I doubt the alternator needs replacing though. And yes, that panel should pop off fairly easily.
Old Jan 30, 2019 | 06:50 PM
LittleRed2014
Thank you
Old Jan 30, 2019 | 06:51 PM
LittleRed2014
Thank you
Old Jan 30, 2019 | 08:04 PM
chrunck's Avatar
chrunck
Taking off the cowl over the battery isn't too bad, though it's kind of tricky the first time you do it. Going from memory:
1. Put a piece of painter's tape on the windshield above and below the passenger side wiper war (makes alignment during reassembly easier)
2. Pop off the passenger wiper arm (wiper removal tool is recommended)
3. Remove nuts holding the cowl on (there are 2 or 3)
4. Remove the gasket running along the front edge of the cowl (goes completely across the engine bay, should just slide off)
5. Slide a screwdriver between the two pieces that the gasket was over and disengage the clips
6. Pull the cowl up slowly and it'll separate from the windshield
You may be able to do it without removing the wiper arm, but I cracked my cowl when I tried that, so I just take the wiper arm off.
This isn't a countryman in this video, but it's the same basic procedure:
fishbulb
Jan 2, 2012 09:27 PM
MikeyFire
Mar 29, 2009 08:46 PM
pimpedout97x
18
Oct 3, 2007 08:20 PM
Mark
DC Metro MINIs (Archive)
Jan 3, 2006 12:25 PM
