R60 Intake Manifold HELP!
Old Jan 26, 2019 | 04:27 PM
Marius26's Avatar
Marius26
Post Intake Manifold HELP!
I was changing the engine air filter in my 2011 Countryman S today when I came across a loose hose. It took me a while to find the name of it but this diagram says it's called the intake manifold. (No. 7) In any case, I tried to push it in but it wouldn't stay in place. Is there a pin or clamp that is needed to hold it in place snuggly?
Thanks!
Old Feb 1, 2019 | 11:13 AM
MrGrumpy's Avatar
MrGrumpy
Ok, #7 on the diagram you linked is actually just an elbow in the fresh air intake pipe going to the airbox. It should snap together. It’s a bit oblong, not round and has a couple of raised bumps or tabs that lock into matching holes on the other pipe. The other end just twists into the airbox. It’s not anything that will be a problem, but it does supply cool fresh air to the intake. Worst cast, you can put a little black duct tape around it. It doesn’t hold any pressure or anything just air coming into the filter.
Old Feb 19, 2019 | 03:03 PM
Marius26's Avatar
Marius26
Talking
Thanks, Mr. Grumpy!
sddiver619
Sep 5, 2018 07:49 PM
Eric.
Jun 5, 2017 06:32 PM
kb30
Feb 14, 2012 06:15 PM
lamia
Want to Buy - All Other Items (archive)
12
Jul 20, 2008 07:29 PM
Dr Obnxs
Sep 2, 2006 09:41 PM
