R60 Auto Transmission Service
Old Aug 16, 2016 | 06:55 AM
pbkirby's Avatar
pbkirby
Has anyone changed the fluid and filter on the CMS ? Forum search comes up empty. My wife's ride has 75K miles and was thinking of doing it as a preventative. Dealer says "lifetime" fluid, I'm not buying it, no such thing as a fluids break down with heat over time. Appreciate any thoughts on the topic.
Old Aug 16, 2016 | 11:49 AM
frankthetank77's Avatar
frankthetank77
I'm interested too as the dealer told me the same thing. Has transmission fluid come so far that its breakdown is non-existent or what?!?
I hope someone has some insight to this.
Old Aug 16, 2016 | 11:56 AM
DaGriz's Avatar
DaGriz
Pelican Parts site has the instructions http://www.pelicanparts.com/techarti...uid_Change.htm
Old Aug 16, 2016 | 03:33 PM
pbkirby's Avatar
pbkirby
Pelican article is close but its not for a CM
I believe the fill process is different, especially location of the fill hole.
Old Oct 5, 2016 | 10:44 PM
bmwr606's Avatar
bmwr606
my buddy owns a transmission overhaul shop
i have access to the aisin manuals
there is a tool for filling the transmission that screws into the drain plug hole ... it has a nipple on it to put a hose on ... you can fill the transmission in just a couple minutes using the tool ... the fluid will not come out when you remove the tool, the standpipe keeps it in
the aisin manual says to measure the quantity of fluid drained and to add that much back then run the car through the gears as described below then reinstall the tool and top off the transmission
i have done this twice to my sisters all4, i have a manual in my all4, it goes much faster than using the top fill hole
a trick i have learned is to drain the oil hot, then let the car sit untouched over night ... i have gotten an extra 1-2 quarts to drain overnight
Old Nov 15, 2016 | 11:29 AM
max2105's Avatar
max2105
there is a tool for filling the transmission that screws into the drain plug hole ... it has a nipple on it to put a hose on ... you can fill the transmission in just a couple minutes using the tool ... the fluid will not come out when you remove the tool, the standpipe keeps it in.
Hi,
Thanks for that great tip! Where would one find such a tool?
Sergio
Old Nov 19, 2016 | 09:49 AM
bmwr606's Avatar
bmwr606
asttool.com
Old Mar 3, 2017 | 11:46 AM
max2105's Avatar
max2105
I used this tool and it worked great.
OEMTOOLS
OEMTOOLS 24441 Manual ATF Filler System ($86.99 in Amazon)
Quickest tranny fluid change I've ever done.
I use Valvoline MaxLife Synthetic ATF on all my vehicles and it not only works great, but it also costs a fraction of the price of the "only use this fluid brand or your car will explode" fluids.
panschel
May 8, 2016 08:10 AM
Greggz
17
Apr 26, 2016 12:51 PM
Frixos
Apr 3, 2016 06:12 PM
AlphaQuad
Mar 29, 2016 07:07 PM
PureSilver
12
Aug 27, 2002 01:36 PM
