R60 OEM Exhaust modification
Old Mar 4, 2016 | 11:22 AM
exdos's Avatar
exdos
This is my first posting on the forum. I'm in the UK and I've been following this great forum for a while and bought a Countryman Cooper S just over a week ago.
I've immediately installed a Westfalia detachable towbar to tow my Rotax Max go kart on a small trailer. Whilst I was doing the job, I took a good look at the OEM exhaust with a view to gutting the OEM silencers to improve flow and increase power/torque. I've previously done this to other BMW cars with OEM stainless steel mufflers with great success. Before I do this to my Countryman, I'm wondering if anyone has previously done this on a Countryman Cooper S? Can anyone direct me to any photographs showing the internal layout of the OEM muffler so that I can make the neatest cuts? Is the muffler of single or double skin construction and is it of thick enough gauge to reweld easily?
Thanks in advance for any help and advice anyone can give me.
Old Mar 4, 2016 | 11:29 AM
Hello,
OEM US muffler looks like For Countryman All4
Old Mar 4, 2016 | 11:46 AM
exdos's Avatar
exdos
The part number for the US Countryman Cooper S All4 is the same as my Euro spec Cooper S. What I'm wanting to see is a photo showing inside of the muffler when it's been cut open to show the internal pipe layout.
To achieve "silencing" the manufacturers use a layout that creates "reverse flow" inside the muffler, and what I do is remove some of the internal pipework so that the exhaust flow is more direct between the inlet and outlet pipes, but done in a way that doesn't make the car sound unduly noisy. Doing this mod costs me nothing except my time.
I use ECU datalogging to check the before and after performances after "gutting" the mufflers and I've been able to get up to 9% improvement in torque/hp from doing this with a couple of different normally-aspirated 6 cylinder BMW engines. I'm interested to see what gains I'd get with the turbo engine in the Cooper S.
Old Mar 4, 2016 | 12:28 PM
Ah, you want an inside shot. I dont have that. Might have to dig into one.
Old Mar 4, 2016 | 12:37 PM
exdos's Avatar
exdos
I'd really appreciate it if you can find an inside shot and if you could tell me how thick the skin of the muffler is.
Old Jun 21, 2018 | 06:24 AM
rotaryferreira's Avatar
rotaryferreira
great post! i look forward to anymore info you can share
Old Jun 21, 2018 | 10:38 AM
croy90's Avatar
croy90
Hope someone has this shot, as I am very interested to see how this thread progresses.
Old Jul 7, 2018 | 11:09 AM
MrGrumpy's Avatar
MrGrumpy
Well Exdos, it looks like you’re going to need to be the one to open it up and tell the rest of us! I’m curious as to what you ended up doing here.
Old Jul 10, 2018 | 08:38 AM
I never found a shot of the R60 specific exhaust. But if anyone came across one that would be great.
Old Jul 11, 2018 | 08:35 AM
Subw00er's Avatar
Subw00er
I'm familiar with said mod! (I had some fun with an m3 I used to own: http://www.m3post.com/forums/showthread.php?t=253661 )
As its BMW sourced, its likely double walled like the BMW's, but perhaps not since they probably want to save weight. I'd expect a few different chambers in there, likely a helmholtz in there somewhere. I'd cut on top or back the tip side first and see whats there. You could always drill an inspection hole to see if you hit metal threads/baffle material.
I'm keeping my eye out for a used JWC r52 exhaust.. I'd like to see what a valve would do on this little mini..
Tires, Wheels & Brakes
Jan 30, 2016 09:35 AM
greekzilla
Jan 26, 2016 11:13 PM
Cmv138
Jan 20, 2016 12:00 PM
Eugene Arnold
R58 :: Coupé Talk (2012+)
Jan 20, 2016 09:12 AM
molala
Jan 17, 2016 11:24 PM
