R60 Leaking green fluid 2013 countryman
Old Nov 14, 2015 | 10:24 AM
smwzuu's Avatar
smwzuu
I just got a 2013 countryman and it is leaking green fluid. Thoughts? It is not oil.
Will the leak be covered under 3 yr bumper to bumper warrenty?
Old Nov 14, 2015 | 10:59 AM
minicountry's Avatar
minicountry
Yes water pump kaput, just like mine
Old Nov 14, 2015 | 11:13 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
S/be blue coolant in most cases, i would make sure car is flushed properly at repair time.
Old Nov 14, 2015 | 11:23 AM
smwzuu's Avatar
smwzuu
My wife is out driving car. She said the temp light just came on. Should we pull over and tow.
Old Nov 14, 2015 | 11:34 AM
Fly'n Brick's Avatar
Fly'n Brick
Take her a jug of water and refill the coolant tank then get it in for service. Also, it's always good to make it a habit of checking ALL fluid levels regularly unless you live for surprises.
Old Nov 14, 2015 | 11:45 AM
Minnie.the.Moocher
It should be covered by Mini, I'd let them come get it. If you drive and all the fluid comes out quickly you might do major damage.
Old Nov 14, 2015 | 01:51 PM
smwzuu's Avatar
smwzuu
Thanks Ya'll got it over to service this afternoon.
Old Nov 14, 2015 | 02:44 PM
minicountry
You might overheat your engine if you don't get it fix
Old Nov 14, 2015 | 06:17 PM
dpike's Avatar
dpike
mine JUST came out of the dealer for fixing the thermostat housing for the second time in two years. it's common that they go bad and crack as well as the waterpump failing.
Tylerlanger1
Dec 9, 2015 03:55 PM
ZeroKelvin
Nov 18, 2015 04:46 PM
Raptor911
Nov 14, 2015 06:11 PM
VolperCooper
Nov 13, 2015 08:19 PM
YoloSapien
Nov 13, 2015 11:33 AM
