R60 rear seat/trunk divider
Old Nov 3, 2015 | 11:56 AM
happychap's Avatar
happychap
I am a new countryman owner. I bought a used 2011 with the 2 rear bucket seats.
I do not like that there is an opening between the 2 bucket seats and the trunk. I have the flat load floor and know I can lift it to create a divider, but then I no longer had a flat load floor which I like.
Has anyone either bought a second flat load floor or something else to create a permanent divider between the rear seat and the trunk?
Old Nov 3, 2015 | 03:21 PM
bmwr606's Avatar
bmwr606
if you have only one then you do not have the flat load floor option
all the cm with bucket rear seats had the divider, the flat load floor option added a second piece that covered the well
Old Nov 3, 2015 | 06:57 PM
bandwagn's Avatar
bandwagn
Agreed - it should look like this
rear seat/trunk divider-image-2522407725.jpg
Old Nov 3, 2015 | 08:22 PM
bmwr606's Avatar
bmwr606
you can buy the 2nd floor, but it is very expensive because the sidewall plastic trim has to be replaced along with a bunch of other parts ... somebody added it up once ... it was about $1000 plus install
Old Nov 3, 2015 | 11:26 PM
PureWorks's Avatar
PureWorks
Have the same issue...I'm going to have one made..ill provide details, costs and pics when done
Old Nov 4, 2015 | 10:18 AM
Some info here: 51479811135
https://www.northamericanmotoring.co...ard-floor.html
https://www.northamericanmotoring.co...d-floor-2.html
Old Nov 4, 2015 | 07:06 PM
happychap's Avatar
happychap
Thanks for the replies. So it sounds like I have the standard floor and will just have to live with the well not covered when I have the floor raised behind the seats.
Old Feb 1, 2018 | 02:50 PM
LTLMCPE's Avatar
LTLMCPE
Did you ever get one made? I just picked up a 2013 R60 and am very surprised to learn there is not a simple flat cover piece I can acquire at reasonable cost. I had not idea there was difference between the bucket and bench seat versions.
Old Feb 8, 2018 | 10:19 AM
I have not seen one yet.
Tigger2011
Mar 26, 2016 05:23 PM
Beau B
R60/R61 Stock Problems/Issues
14
Dec 15, 2015 04:56 AM
Z0RR0
Suspension
Nov 3, 2015 08:50 AM
Nov 1, 2015 12:02 PM
blue al
Suspension
Oct 30, 2015 12:42 AM
