R60 MINI Connected and iPhone 6/Plus
Old Feb 15, 2015 | 11:06 AM
jennayrich's Avatar
jennayrich
Does anyone know if you can just use the Apple USB cable (USB/Lightning charging cable) to connect and use MINI Connected with an iPhone 6 plus?
I've got MINI Connected w/nav and have been trying to use the Apple USB cable, and sometimes it will work with the app on my phone, and other times it seems to get stuck on the initial "connecting..." screen.
Old Feb 15, 2015 | 12:09 PM
siriuszero's Avatar
siriuszero
No...the MINI Y-cable is required
Old Feb 15, 2015 | 12:49 PM
jennayrich's Avatar
jennayrich
Do you happen to know which cable I need for an iPhone 6 Plus?
Old Feb 15, 2015 | 12:51 PM
siriuszero's Avatar
siriuszero
Please reference this thread: https://www.northamericanmotoring.co...phone-6-a.html
Old Feb 15, 2015 | 04:35 PM
Pure Red's Avatar
Pure Red
Hmm, we have MINI Connect on our 2012 CM S. We use a Pro-Clip phone dock to power up the phone for charging, but Bluetooth Stream either of our iPhone 6s'[ 1 is a Plus , 1 is a regular 6] for audio play of our music library.
I only use the BMW/MINI Y cable in my 2012 Clubman which does not have Connect. Had to get the infamous Y cable since the Apple cable is not 'recognized'.
We were happy to have the wireless streaming ability in the Countryman since it meant no cable connections except for charging.
Old Feb 15, 2015 | 05:00 PM
jennayrich's Avatar
jennayrich
I've found a couple of threads that talk to this, but they aren't very specific in the type of Y cable you need for MINI Connected. I can stream music and calls through Bluetooth, but I believe (based on what I've seen in previous threads) you need a Y cable to have audio play when using MINI Connected and the MINI Connected app. I can use my Apple USB cord, but it won't push audio through my car system. I believe this is the Y cable you need for iPhone 6/Plus and MINI Connected WITH nav:
http://www.ebay.com/itm/like/291191295887?lpid=82&rmvSB=true
A bit pricey, and unfortunately I didn't get anything besides the owner manual with the MINI Countryman S I purchased recently. I'll verify with the dealership tomorrow before spending nearly $90 on a cable.
Old Feb 15, 2015 | 09:44 PM
frozen black's Avatar
frozen black
the original lighning cable is working in mine MY 2014 with iphone 6, have change only in the " Media " controller the encoding in USB1_IPOD_AUDIO from "analog " to " digital". And now does the sound coming out with Lightning cable and all of the rest is working too.
MFG
gente
Old Feb 16, 2015 | 09:38 AM
barchstein's Avatar
barchstein
MFG
gente
can you elaborate? where did you change the USB1 iPod audio from analog to digital???
thanks in advance for your reply.
regards
barchstein
Old Feb 16, 2015 | 10:04 AM
cosmic_R60's Avatar
cosmic_R60
regards
barchstein
I'd like to know this too.
Old Feb 16, 2015 | 04:34 PM
TJANK's Avatar
TJANK
http://www.ebay.com/itm/like/2911912...=82&rmvSB=true
Be mindful Mini has different Y connectors. If you have Mini Connect it should had come with the delivery. Of course, they provided me with the incorrect Y-connector. One is designed for Mini Connect which actually has a triangular connection joint. There is also one with a rectangular connector which does NOT work Mini Connect. Once I added the Apple lightning adapter to the triangular Y-connector, it worked.
Old Feb 16, 2015 | 09:43 PM
frozen black
regards
barchstein
...coding the media controller with an OBD cable!
MFG
gente
Old Feb 20, 2015 | 08:08 AM
Macavity72's Avatar
Macavity72
Mine came with the wrong Y-cable. It came with the 61122287642 music cable, which is not for use with MINI Connect/Nav. I had to get them to swap it for the 61122287505 media cable.
Dec 23, 2015 10:36 AM
tippin
Aug 5, 2015 08:43 AM
