R60 Interesting observation
Old Oct 27, 2014 | 08:46 PM
mickeymo's Avatar
mickeymo
I don't have the Mini Connected option on my Countryman. I noticed today that if I start my car, stop it and then pull out the key fob, I can start the car again without reinserting the key fob.
Not sure what use this would be to anyone, but thought it was interesting...
Old Oct 27, 2014 | 09:26 PM
FredoinSF's Avatar
FredoinSF
Connected has nothing to with that. Do you have comfort access??? That's the feature that allows starting the car with the key in your purse.
Old Oct 28, 2014 | 11:27 AM
mikey_t's Avatar
mikey_t
Mine does this also but wont do so once you open the door. Neither MINIConnected or ComfortAccess appears to have anything to do with this since i dont have either option.
Old Oct 28, 2014 | 02:17 PM
mickeymo's Avatar
mickeymo
I meant comfort access, not mini connected...
Old Oct 28, 2014 | 03:13 PM
LILYisatig3r's Avatar
LILYisatig3r
Mine is the same. My previous MCS had comfort access and I could start the car without the key in the slot all the time. However, my '11 fJCW doesn't have comfort access and I can only start it without the key right after I turn it off again, before I open the door. Once I've opened the door or if I try to do it again later on a different drive, it won't let me do it.
So bizarre.
Old Oct 30, 2014 | 04:52 AM
HateRegs's Avatar
HateRegs
I believe you'll find this listed in the manual under valet. The idea is you can for a short time restart the car and let the valet drive it to a parking spot but not leave your key with them.
Old Oct 30, 2014 | 07:42 AM
mikey_t's Avatar
mikey_t
I dont think so. Mine wont restart without the key once i open the door so unless the valet guy/gal and i want to crawl in/out thru the window that might be difficult.
Your suggestion may work if you have Comfort Access though which the OP indicates he doesn't.
Old Oct 30, 2014 | 08:51 AM
HateRegs's Avatar
HateRegs
I believe the expected usage is:
1) you drive up to the valet stand
2) you take the key out and the car turns off
3) you start the car back up(foot on brake push button without opening door)
4) you take your key with you and get out of the car so the valet can get in.
5) valet gives you receipt and you keep your key
6) valet parks car and turns it off and cannot go out joy riding.
7) you return later for your car and give valet key and receipt.
earlier thread on the feature here: https://www.northamericanmotoring.co...ew-mini-s.html
I'm personally with the person in the thread who says the best solution is to self park. I'm just cheap that way.
Old Oct 30, 2014 | 09:23 AM
y8s's Avatar
y8s
so wait, OP has comfort access and can start his car without the fob in the dash?
that's how it's designed.
Old Oct 30, 2014 | 09:35 AM
mikey_t's Avatar
mikey_t
Hateregs: I agree. I wouldn't waste the $ on valet parking. I'll have to try steps 3/4 again to see if my car keeps running when i open the door after restarting it without the key in the ignition. Unfortunately that'll have to wait until my car gets back from my wife out joy-riding in it...
As for y8s.... no, the OP does not have Comfort Access. Re-read post #1 and #4.
Old Nov 2, 2014 | 11:27 AM
mikey_t's Avatar
mikey_t
okay, tested my car and it works as per steps 3/4 in HateReg's post. Next issue is the valet revising step 6 into 'valet goes for joy ride first then eventually parks your car'.....
Old Nov 3, 2014 | 06:19 AM
The X Men's Avatar
The X Men
deleted
Old Nov 3, 2014 | 03:33 PM
cooperjunkie's Avatar
cooperjunkie
I use it in the mornings when I warm up my car. We don't really have much use for valet in Kentucky but its great when its freezing cold out. Start, turn off, take out key, restart, get out, lock the doors and let it warm up. I know its not efficient on the car but it beats the hell outta freezing in the car for 10 mins before it warms up.
Old Nov 24, 2014 | 02:11 PM
enigmaintx's Avatar
enigmaintx
Awesome! I learned something new today!
Cheers
Old Nov 24, 2014 | 03:20 PM
mikey_t's Avatar
mikey_t
Cheers
JamesDeBart
Apr 16, 2016 05:00 PM
GAT
Oct 4, 2015 07:27 PM
mini merle
Sep 30, 2015 04:42 PM
aldito2
Sep 30, 2015 10:44 AM
Emnotek
Sep 29, 2015 07:37 AM
