R60 Silver turn signal bulbs for a 2013?
Old Aug 13, 2013 | 07:10 AM
EHans's Avatar
EHans
Anyone know if Mini changed the turn signal bulbs in the 2013's? I ordered a pair of the silver bulbs from Way Motor Works, but they are the wrong ones. I've emailed them so will see what they say, but in searching theirs and other sites, it seems all of the silver bulbs are single filament. Mine are dual filament and have two contact points in the bulb and socket. A single contact bulb won't work.
Maybe it is a late 2013 change? Lana was built the first week of June. Anyone with a CMS have success in replacing the front turn signals with a non-yellow bulb?
Old Aug 13, 2013 | 07:21 AM
DKIKK77's Avatar
DKIKK77
Mine were 2357. Dual filament and two contact points. That's on a 2012 though. It should say on the bulb.
Old Aug 13, 2013 | 08:08 AM
ljmattox's Avatar
ljmattox
Likely Countryman(s) are different, but for my 2012 MCS I had to buy one of each (and actually a pair of each), single- and dual-filament.
The passenger side is dual-filament, I think due to that Euro-spec "leave the right side illuminated when parked" function. Anyhow: it really did use dual-filament on the passenger side, single-filament on the driver's side.
Look great, after all that :-)
Old Aug 13, 2013 | 09:02 AM
sbdubya's Avatar
sbdubya
If you haven't already you'll need to pull the bulbs and order the # located on it. Mini uses two diffent bulbs. Check out sixity.com for their selection of bulbs that is where I got mine.
good luck!
Old Aug 13, 2013 | 12:40 PM
EHans's Avatar
EHans
How does the number help? I put in the number Dkikk77listed above and got results not found.
Old Aug 13, 2013 | 12:49 PM
EHans's Avatar
EHans
Tis looks right, but says rear turn signal. http://www.sixity.com/silver-off-amb...nal-bulbs.html
I'll have to research. I hate electrical. Watts, ohms, Volts, amps, ugh.
Old Aug 13, 2013 | 02:45 PM
DKIKK77's Avatar
DKIKK77
Did you check your stock bulbs? These are what i got.
http://www.mrbodykit.com/index.php?m...roducts_id=408
Old Aug 13, 2013 | 05:19 PM
EHans's Avatar
EHans
Thanks for the link. I didn't write down the number on the stock bulb. I just noticed it wasn't what I was sent and frustrated, I put it back. I'll see what WMW says. No response so far. :-(
But your link looks exactly like my bulb, so it does exist.
Old Aug 14, 2013 | 04:18 AM
EHans's Avatar
EHans
WMW responded. New bulbs will be on the way early next week. Hopefully that will fix it.
Old Aug 14, 2013 | 09:15 AM
etidd01's Avatar
etidd01
E, be sure to let the rest of us know the bulb number!
Old Aug 14, 2013 | 09:22 AM
irondawg's Avatar
irondawg
Or just paint the originals with a light coat of silver. I've done this when I first got the car. All is good still.
Old Aug 14, 2013 | 02:08 PM
EHans's Avatar
EHans
I definitely will. I'll take pics and stick them in Evernote for future reference, so I'll post the data here as well.
barnoun
Sep 17, 2018 05:04 PM
Dec 23, 2015 10:36 AM
WayMotorWorks
Aug 25, 2015 10:01 PM
HCClubbie47
R55 :: Clubman Talk (2008+)
Aug 24, 2015 02:16 PM
missinmyjeep
Aug 22, 2015 07:13 PM
