R60 Flutter or rattle comming from the front right during high speeds?
Old Jul 6, 2012 | 04:17 AM
preme123's Avatar
preme123
What can it be? Is it the windscreen seal or something? Looked all over the place and don't seem to find what's fluttering or rattling. Everything seems tough and strong. The console is neat and tight too.
the faster the car goes or higher the wind is, the more rattles/flutter sounds!
What do you think it is? please help thanks just got off from service changing all four brake pads, too lazy to go back again!
Old Jul 6, 2012 | 06:07 AM
razz's Avatar
razz
Check to make sure the sidelight is snug. On my MCS, one of the tabs had broken off mysteriously and was rattling in the slot.
Old Jul 6, 2012 | 06:36 AM
Koopah's Avatar
Koopah
Did you start hearing the sound after you got it back from service? If so, check everything in and around the wheel-wells. Lug bolts? The round access covers to the front lights? Trim/mudflaps?
Check the pads in the calipers. Can you duplicate the sound (in neutral) with the wheels off the and spinning quickly?
Old Jul 6, 2012 | 07:36 AM
preme123's Avatar
preme123
Nope, sound occurs at high speeds, I drove through some bumpy roads and potholes to check if I could duplicate the sound. But No. It happens only at highway speeds. I think it's an issue with wind hitting the front windshield or something to do with wind i suppose?
I'll check the mudflaps and wheel wells tomorrow if it's ripped or anything.
Old Jul 6, 2012 | 10:08 AM
el_Zilcho's Avatar
el_Zilcho
Mine makes a wind noise that sounds like the front right window is slightly open. It isn't, haven't figured out what it is.
Old Jul 6, 2012 | 10:13 AM
Mojito's Avatar
Mojito
Do you have a sunroof?
Old Jul 6, 2012 | 07:51 PM
preme123's Avatar
preme123
Yes I do have a sunroof.
Old Jul 6, 2012 | 07:56 PM
Mojito's Avatar
Mojito
See the 1st thread in the fixing problems sub forum. There are 2 plastic tabs that need to be removed under the hatch
Old Jul 6, 2012 | 09:05 PM
preme123's Avatar
preme123
But the sound is comming from the front right of the windscreen of the car tho. I'll get the two clips out today and report if I solved the problem!
Old Jul 6, 2012 | 09:22 PM
Mojito's Avatar
Mojito
There's one on the right and one on the left. Seems weird, I thought it was the seat belt flopping around, but at last this fixed it
Old Jul 7, 2012 | 10:06 AM
creep's Avatar
creep
could it be the battery clips?
https://www.northamericanmotoring.co...r-rattles.html
Old Jul 7, 2012 | 11:20 PM
preme123's Avatar
preme123
Originally Posted by creep
OMG thank you so much! this solved it wowwww THank you so much!!
TREX
Nov 2, 2019 07:31 PM
Pyrs
R55 :: Clubman Talk (2008+)
19
Sep 8, 2015 01:43 PM
iclancy82
Aug 11, 2015 09:35 AM
Dashdog
Aug 10, 2015 06:17 AM
