Save your money for Mods
Old Apr 28, 2006 | 12:54 AM
2006mcsasteve's Avatar
2006mcsasteve
To you soon to be, or new Cooper S owners, put aside a small amount of money to make some effective upgrades.
I do say small, because relatively speaking most of these can be done fairly cheaply.
Find a local Mini shop that can be trusted (you can often search the threads for someone near you).
For performance:
15% pulley reduction
New CAI (cold air intake, sometimes called airbox)
New spark plugs
For handling, especially if you plan to do any track days
22mm rear sway bar
For braking, again especially if you are doing track days
New front pads
New brake fluid
Unless you live in a place that snows, get the most performance tires that are offered when you buy.
You can get all of the above for about $600-700 and then have it all installed for another $500 or so.
It must be mentioned, for posterity, that you can void the warranty on the specific pieces you change, but all of these mods have been seriously vetted by hundreds, if not thousands, of Mini owners over the last few years with very few problems.
Happy Motoring!
Old Apr 28, 2006 | 05:40 AM
Turcicus's Avatar
Turcicus
A newb question - is the CAI something that you can install yourself, or does it require going to a shop?
Old Apr 28, 2006 | 05:54 AM
flannelhippie's Avatar
flannelhippie
I have never done it on a Mini, but I have done it on a ton of other cars, and it was easy as pie.
Old Apr 28, 2006 | 06:15 AM
RHM's Avatar
RHM
For mods, I have read (posts from those that have installed them) that plug wires really don't make any noticeable change, but how about the plugs that you suggested? As this would be an inexpensive change, does it make a noticeable (or measureable) difference?
Old Apr 28, 2006 | 08:17 AM
snid's Avatar
snid
I changed my plugs from the stockers with 90,000+ miles on them to those fancy Denso iridium ones. I noticed.... wait for it... absolutely nothing.
But, I've got a Cooper, not an MCS, so I obviously have some issues and should not be trusted.
Old Apr 28, 2006 | 12:03 PM
mcsdmn's Avatar
mcsdmn
well i had an old nissan pickup and when i changed the plugs from regular ones to Denso iridium dual something plugs the truck felt a little more responsive.........
don't know about the MINI haven't changed those.
Old Apr 28, 2006 | 12:09 PM
Doogs's Avatar
Doogs
What impact does the 15% pulley have on warranty?
Voided warranty on supercharger and/or engine = no thanks, I'll wait
Old Apr 28, 2006 | 12:29 PM
Dr Obnxs's Avatar
Dr Obnxs
Welcome to the modding world of Minis!
Pulley is the best bang for buck you can do (not counting nitrous!). Warranty depends on you dealer... Heck, some even install them!
If you want to save even more $, look up the HAI (K&N filter directly on the throttle body). It's under $50. There's a thread where someone will bend you a CAI box for about $50. But this is a very, very easy to do mod. If you're comfortable with a socket wrench and screwdriver, you can do it.
Colder plugs are to keep cylinder temps down on pullied cars, and there are varying opinions on their efficacy.
The rear bar will help balance the car better, but start easy and work your way up the stiffness settings. Don't want the wrong end pointing down the road!
Pads and fluids help the brakes, as does metal caliper bushings. Look in the reviews section under brakes....
Anyway, there are folks who've "been there, done that" all over the boards.
Use the search function, and don't be afraid to ask.
FWIW, MC Squared just did a "First 5 mods" article (that I wrote), but there are also how to articles with photos. LAst issue had CAI, and next one has front brake pads.
Have fun!
Matt
daidaibi
Mar 21, 2016 08:25 AM
pewx3
29
Jan 15, 2016 11:14 AM
nashvillemini
Sep 30, 2015 10:26 PM
LAcooper
Sep 22, 2015 10:03 PM
Sep 4, 2015 03:56 PM
