New Mini Owner (Kind Of)
Glad to help
We have not updated yet, we should have it soon. Most of the stuff is the same on the 2021 unless its LCI specific like the newer design oil filter or body components.
Intake you will need the LCI version, you will see it on our site labeled, but no one has confirmed on the 2024 JCW yet, hopefully MINI did not change anything again, Wheel spacers are the same as all F56 MINIs 5x112 66.6CB
I can help you, the newer design is on the site with 2021. Its the Maf sensor that's the change lci, that's what i saw looking at the 2024 engine bay. Also i asked NM last time and they could not confirm 2024 JCW.
MINI has been changing things a bunch on the F56 LCI through the years.
Yep forge has had some delays, I would go for another one if you cannot wait.
NM Engineering LCI +
https://www.ecstuning.com/b-nm-engin...engine-intake/
Wheels nothing really changed, you can pick 2021 JCW. https://www.ecstuning.com/Mini-2021-...market_Wheels/
Some people did say the caliper on the F54/F60 JCW changed (less room i guess). I have not heard anything on the 2024 F56 JCW
Welcome.
by any chance, have you heard anything from H&R for the 2024 JCW? I looked at their site today and they still don’t list any.
They could not confirm. I would just do the 2023 ones as i dont see anything that changes on oem part numbers for the 2024. Most aftermarket companies are very slow to update as they are focused on all Makes, not just MINIs, so they update ford, BMW, JDM cars etc first.
Still looking for an Intake for my 24 JCW, The Forge one never came off backorder. I looked on ECS Tuning at the AFE cold air intake Momentum GT 50-70068D That ECS Tuning states will work but when I look at AFE site it will only fit 2019-2019 JCW so a year later I'm still confused which intake will fit
Let me double check with them, some vendors we work with are slow to update on their site.
The big thing on intakes is the stupid maf design changed on/in 2018-2019 models and you have to double check the MAF sensor.
OK Thanks... MAF is no problem being they changed that in 2019 my 2024 has the new design. AFE site has a green check mark on my MAF but states only fits 2019-2019 JCW which is weird.
Yep, they are looking it to it as we speak
They said should fit till 2024 and they will update site soon.
Thanks... Any chance you could check on the H&R lowering spring? I looked on H&R USA site and they are not listed for the 2024 or even the 2023. I know your site list them MF# 28813-1 but not sure where you guys are getting the info they will work?
They are slow like other vendors, i just had to tell aFe about a fitment correction. Usually our site is more up to date then the distributor, we have MINI ETK and knowledge. Thats how is been since I started building the site in 2012.
OK... Thanks So I can order the H&R springs from your site ever though H&R doesn't list them for 23 or 24 JCW?
Yep.
mjmurray68
F54 :: Clubman Talk (2015+)
11
Feb 26, 2017 08:39 PM
