Cylinder 1 misfire
Old Dec 14, 2022 | 08:52 AM
Traiwilliams's Avatar
Traiwilliams
Cylinder 1 misfire
Mini Cooper r50 2002
Hi
currently got a misfire in cylinder 1 on idle and under load. I have changed spark plugs, coil packs and injectors and still misfiring. Engine light comes on only sometimes but the misfire is constant. Wondering if it’s the exhaust valves but not sure as I’ve done the paper/ tissue test on the exhaust exit (not sucking the paper/tissue back in). Anyone have any suggestions?
Old Dec 15, 2022 | 05:30 AM
hailey grey's Avatar
hailey grey
Welcome to the forum
Old Dec 15, 2022 | 12:50 PM
zabond's Avatar
zabond
Welcome And a couple of questions, how did you determine it was #1 cyl & what was the colour of the spark plug electrode from #1 compared to the other 3, did you do a compression test,? As you have already replaced most of the elec components & injectors it does sound compression related
Russ from downunder
Old Dec 16, 2022 | 05:54 AM
Traiwilliams
Russ from downunder
I plugged a code reader in and it came up with cylinder 1 misfire and engine running too lean.
all spark plugs were not wet, they were dry however,
whilst screwing in cylinder 1 spark plug it didn’t seem to get tight enough to stop screwing, it just kept turning which I found weird.
Old Dec 16, 2022 | 12:53 PM
zabond's Avatar
zabond
if your saying that #1 spark plug would not tighten then it would not be sealing in the head and could be sucking in air on the intake stroke, causing your lean/misfire problem, the cause would probably be a stripped thread in the head, which is a major problem, remove the plug and get a flashlight to inspect the thread in the head, if it's just turning on not tightening you should be able to see the damaged threads
good luck
Russ
Old Dec 16, 2022 | 05:04 PM
Mini-Titan's Avatar
Mini-Titan
Hope it is the spark plug threads that are stripped and not the head. You DEFINITELY have stripped threads on at least one of the surfaces. Sorry.
Old Dec 19, 2022 | 11:27 AM
Heli coil if its stripped out.
https://www.ecstuning.com/Mini-2003-...Thread_Repair/
Old Dec 19, 2022 | 12:20 PM
Traiwilliams
okay thank you, I’ll have a look!
sparky814u
Oct 27, 2022 09:48 AM
jctrue
Sep 3, 2021 10:21 PM
Jordan Smythe
Jun 11, 2021 12:32 PM
Mayfair
Apr 14, 2021 10:10 PM
FrankBlack
R55 :: Clubman Talk (2008+)
Nov 5, 2019 10:22 AM
