Cylinder 1 Misfire
Old Sep 2, 2021 | 03:46 PM
jctrue's Avatar
jctrue
Cylinder 1 Misfire
Just purchased a 2007 S with 108,000 miles. The check engine light came on indicating a misfire in cylinder 1. Took it to the mechanic and he has replaced the following:
Spark Plugs
Coil Pack
Fuel Injector
He drove it about 60iles and there were no issues. Today on my way home from work, light comes on again, same code, and then it would intermittently run rough, loose power, and the light would flash. Ran a compression test and got these results:
Cylinder 1 120
Cylinder2 150
Cylinder 3 148
Cylinder 4 150
Mechanic says the 120 is not enough to cause the misfire and he believes it is electrical because it is interermittant. He wants to replace the computer. Does this sound correct? I am at a loss here.
Old Sep 3, 2021 | 07:13 PM
ssoliman's Avatar
ssoliman
How about the plug wire? Swap it as a test
Old Sep 3, 2021 | 10:21 PM
OCR's Avatar
OCR
Is the 07 a coil on plug engine ?
If so, there are no "plug wires" like earlier engines.
If yes, did he check the coil connector and wires for broken or chafing wire ?
If it does have the large 7 (or 8)mm wires, then yes, the wires should have been replaced with the spark plugs and coil.
MIke
Jordan Smythe
Jun 11, 2021 12:32 PM
r56_tyler
Apr 26, 2021 05:26 PM
Mayfair
Apr 14, 2021 10:10 PM
FrankBlack
R55 :: Clubman Talk (2008+)
Nov 5, 2019 10:22 AM
Streakerr
Jul 16, 2013 08:51 AM
