New Mini Owner, coolant leak already !
Old Apr 20, 2021 | 09:09 PM
Mini owner's Avatar
Mini owner
Just got a 2007 Mini hatch, base model R56 with an N12 engine. Thermostat was supposedly bad so I bought a new housing from the local Mini dealer. I replaced the bad one but coolant is leaking from the housing/tube joint were the clip goes. I guessed that I installed the clip wrong. Looking more closely at this joint it looks like the groove for the clip is still outside of the tube ! Can this be possible ?
Old Apr 21, 2021 | 05:13 PM
miniCPA's Avatar
miniCPA
Welcome to the forum. Hopefully you can workout your initial problems and you can begin to enjoy the MINI adventure.
Old Apr 27, 2021 | 07:42 AM
Check out this here: https://www.northamericanmotoring.co...-question.html
You have to make sure the install is correct. Thats half of the problems.
Old Apr 27, 2021 | 09:37 AM
Mini owner's Avatar
Mini owner
Thanks for the advice, I went to auto parts store and bought some silicone grease. I took housing off again, applied grease to o-ring, re-mounted the housing. Then came the fun part, inserting the clip properly ! After almost an hour and a trip to the store for long needle nose pliers I got it on properly. The tube was not short like I thought. I think the lack of silicone grease was cause of the leak. Mini runs great now and no leak 😃
Old Apr 27, 2021 | 01:07 PM
Thanks for the update.
quikdime
Jul 5, 2019 10:17 PM
SooperCuperErik
Dec 16, 2011 11:58 AM
Hedjuk
Oct 22, 2011 08:07 PM
ortuna
May 23, 2010 10:33 PM
subii
Apr 3, 2010 08:17 PM
