Looking for insight
Old Jun 10, 2011 | 03:23 PM
mzutz's Avatar
mzutz
Looking for insight
I have a 2004 Mini Cooper S that has a couple elusive problems. Where/how would I post in order to get some feedback from members?
Thanks.
Old Jun 10, 2011 | 04:52 PM
Vollgas's Avatar
Vollgas
What type of problems?
Please give as much detail as you can.
Old Jun 11, 2011 | 10:56 AM
mzutz's Avatar
mzutz
Two elusive problems
OK, here goes:
Reminder: 2004 Mini Cooper S
Problem #1: An intermittent problem where I'm driving along and suddenly I lose about 75% power and the traction control light comes on. I pull over, turn off the engine, and restart, and everything seems fine.
Background: This happened once about six weeks ago;. Then a few weeks later it seemed to happen again, but this time the engine was sputtering a lot and the problem would not go away when stopping and restarting the engine. My mechanic (independent BMW/European car mechanic) found a faulty ECM and replaced that, along with the ignition coil, spark plugs, and spark plug wires. After that the car ran well for several weeks. Then last week the initial problem recurred - loss of power, traction control light, fixing by stopping and restarting the engine. I don't have the faults codes from the initial round of occurrences, but this last time the mechanic found the following two communication faults in the DSC control unit: FC 5E14, and 5E19 - CAN data error. The mechanic writes:
"Shop tested car for four days, and wa unable to duplicate failure. Technician reinitialized steering angle sensor, and checked applicable fuses/relays. Since no other controllers are registering any CAN data faults, it is likely that the ABS/DSC control unit is experiencing intermittent failure."
Problem #2: There is a strange noise occurring only when the car is thoroughly warmed up and then gets to 70mph or more on the freeway. It is difficult to describe the noise, but sometimes it sounds like a gurgling - other times it sounds like the pinging noise an engine makes when detonation is occurring. (You know - like ping pong ***** under the hood.) The noise seems to be coming from behind the drivers side (on the left, in case any Brits or Aussies are reading ) a/c vent. I am reasonably confident it is not detonation because the noise occurs even if I unload the engine by lifting my foot off the accelerator, or pushing in the clutch, or even putting the car in neutral and coasting at 70mph. So the noise happens based on VEHICLE speed - not engine speed. Once the noise starts, even dropping below 70mph it will still occur, all the way down to about 60mph. BTW, I ALWAYS USE 91 OCTANE GASOLINE, in case anyone wonders.
I mention the second problem here because I don't know if there is any connection to the first problem.
I will gladly repost this in the appropriate forum if someone thinks I should, but here it is.
Thanks.
Mark
lweaver
Sep 17, 2024 08:22 AM
bahman
Sep 30, 2015 01:59 PM
MINI_42
Sep 16, 2015 02:01 AM
laf04mcs
Sep 13, 2015 04:41 PM
mbatech
Sep 10, 2015 03:40 PM
