FS:: Mini Cooper Parts
Mini Cooper Parts Make Offers - Need Gone
Price: $1
Part fits (you may select multiples): R53, R56
Mini Cooper Cylinder Head: Bought the head to port into a JCW car, but sold the car before I had a chance to have it done. The head is an OEM Mini Cooper Head. One of the springs has a crack in it which would need to be replaced, but ECS Tuning sells the spring for $10. It is my understanding that the JCW head for the R53 Mini coopers is the same as the base S head except the exhaust valves are ported, so this head could either be converted to a JCW which would require you to remove the valve springs anyways or it could be a good replacement for your stock head. Asking $450 OBO
Koni Sport Yellow and H&R Springs kit: I have a set of Koni Yellow adjustable shocks that came as a kit with H&R springs. I have not had these mounted yet, but the Koni and H&R sold the shocks and springs together, so the setup will not have any fitment problems. The setup only has 10k miles on it. 600 OBO
Tein Lowering Springs: I have a set of Tein lowering springs that I bought before I decided to go with the Konis $115 OBO
OEM Supercharger $300 OBO
OEM Intercooler $50 OBO
Powerflex PFF5-101 - Control Arm Bushings
Powerflex PFF5-107 - Lower engine support bushing
Powerflex PFF5-108 - Gearbox bushing
I don't have pics of the actual springs, I will try to take some tonight, but they are like these ones.
Are the Teins in similar condition to the ones in the pic or are they cleaner? A real pic would be helpful.
Just FYI, while the base Cooper and Cooper S cylinder heads are nearly identical, the S uses valves with an upgraded material. Would not recommend putting a base Cooper head on an S (unless you change the valves), although the other way would of course be fine.
Cabin9 (08-01-2017)
Ah, okay! Listing just mentioned Mini cooper cylinder head, so I thought it was pulled from a base model. Might be interested in it...will PM you.
