WTB:: Power steering pump wiring
Old 04-12-2015, 03:39 PM
blalor's Avatar
blalor
blalor is offline
Unhappy Power steering pump wiring
Price: $0
I'm looking for the connectors/cables for the power steering pump. Mine melted down, destroying both the low-power control connector and the high-power 100A supply connector and some of the wire. I want the complete high-power cable from the fuse box and ground point all the way to the pump. The control connector appears to terminate in the junction box just behind the water pump; I don't know if it can be unplugged from there, but if not I want as much wire as possible. See attached images for exactly what I need. Please give me a shipped price to 02155. Thanks!
Attached Thumbnails Power steering pump wiring-img_4327.jpg   Power steering pump wiring-img_4329.jpg
Old 04-12-2015, 05:08 PM
bahman's Avatar
bahman
bahman is offline
What yr is your car? Manual or auto?
Old 04-12-2015, 05:33 PM
blalor's Avatar
blalor
blalor is offline
It's an '06 R53 manual. I'm not sure that matters; the part numbers for the power steering pump are the same regardless of transmission and model year.
Old 04-12-2015, 08:56 PM
WayMotorWorks's Avatar
WayMotorWorks
WayMotorWorks is offline
Vendor
I've got the main heavy cable and connector for you. Need to see about the other small connector as they often go with the other harness.
Old 04-13-2015, 08:05 AM
ECSTuning is online now
Received 1,973 Likes on 1,772 Posts
More info here on the harness.
https://www.northamericanmotoring.co...rt-number.html
Old 04-13-2015, 01:13 PM
blalor's Avatar
blalor
blalor is offline
Seems to be plenty of supply of that power cable, but no leads on the other one. Help me, WMW, you're my only hope! ;-)
Old 04-13-2015, 01:36 PM
Here is the connection plug end if you want to wire it yourself. Cut off the old ends and re do them.
#11 61132359998 Comes as a repair kit.
http://www.ecstuning.com/Search/SiteSearch/61132359998/ES2844512/
and
#12 1252143989
http://www.ecstuning.com/Search/SiteSearch/12521439891/
The wires connection: 12520144161
http://www.ecstuning.com/Search/SiteSearch/12520144161/ x 2
Old 04-14-2015, 04:51 AM
blalor's Avatar
blalor
blalor is offline
That's fantastic, Mike. Thanks!
Old 04-14-2015, 05:08 AM
Welcome.
JPMontes3
08-23-2015 01:26 AM
Etrain
14
08-20-2015 10:32 AM
azntaiji
08-13-2015 03:24 PM
minipopkart
08-13-2015 05:22 AM
Quick Reply: WTB:: Power steering pump wiring
