R56 R56 Base P0120, P2102, P1639, P1638, P1637
While driving today in city traffic, I went to accelerate and felt a very brief hesitation followed by engine fail safe mode moments later. Codes P0120, P2102, P1639, P1638, P1637 are displaying in OBD2 diagnostics. Could someone narrow down possible culprit from these combined codes?
bmink@modulardevices.com (11-06-2019)
P2102 throttle actuator control motor circuit low
P1638 throttle valve position control; throttle stuck temporarily.
P1639 throttle valve position control: throttle stuck permanently.
P1637 throttle valve position control: control deviation.
So I know it has some to do with throttle valve and or accelerator pedal and or ecm and or wiring harness faulty. Tried cleaning throttle body intake valve last night with crc with no luck. Anyone experienced with this problem? Welcome input.
Have you attempted to start the engine since you cleaned the throttle body actuator? I'd be surprised if you were able to start your Mini after manually moving the actuator, usually when you move it, the adaptation value needs to be applied for it to work again. This happened when I had my intake valves clean, they were cleaning off the oil residue from the throttle body and actuator. Simply moving the actuator with the engine off puts it out of whack. I'd bet it's you throttle body actuator that's bad, they go bad just like any other sensor.
It's a long shot but the fact that it didn't need the throttle adaptation value reprogrammed might mean you might still have an issue with your throttle actuator, if the sensor is faulty it may not have registered any movement at all when you cleaned it.
Remember the ECU's think that the actuator is stuck, any movement you did probably didn't even register any movement at all.
That's a good starting point, but it's going to be a tug fest getting all the rubber tubing off as I remember doing it 2 and a half months ago to get my VANOS solenoid out. Most difficult thing I did since re-installing my clutch return spring both of which took almost a day!
If you had moved it you most certainly would have had to pay small fee to get the adaptation value reset. You absolutely do not have to go to the dealer to do this, any independent specialty shop could have done this or anyone that does wallnut blasting on the intake valves on BMWs and Mini Coopers.
Hi all, I just bought a nice used R55 Clubman S, so I'm hoping it's similar to the R56 even with base model as almost the same codes probably means a similar issue.
P1637 one time over last week of ownership and P1638 every few minutes it seems. I took throttle body out today and cleaned and yes I moved that butterfly valve manually so many many times to clean. Reinstalled and car fired right up. After a 20 min drive I DID eventually get CEL code 2102 and P1638 again but reset it with scanner reset tool and then took for another spirited drive. Code 2102 and 1637 and 1638 came back with limp home mode directly after accelerating from stop at a traffic light. Then car was RPM searching from 700 to 1,500 rpm while I was stopped in limp home mode.
Anyhow a few posts talk about throttle actuator... Is that the gas pedal or something in the throttle body? Appreciate your help!
willy-mini
05-07-2015 10:35 AM
