R56 Slowly start the upgrade process
I have a '13 MCS which I am going to SLOWLY start upgrading... trying to keep things slow until my factory warranty is up.
I'd like to start with a CAI as it won't void my warranty. What I'd like to know is if the JCW intake is still pretty much the best around to get? (Also, where to get it from other than dealer if possible?).
I don't really want to go with an open filter design (which sucks in hot air most the time anyways) just to get a cool sound. I'd rather stick to the closed design to get a little better performance (not lose my low end torque). I don't care if it doesn't change the sound at all, as I'm after the performance change.
That being said I know I'm not gonna get crazy performance changes... It's just step 1 of a very long upgrading process.
Anyways... JCW (if you could point me to the correct one I'd be grateful) or go with something like the AEM (assuming it's not just a noise thing and gives me some performance).
I know there are a BILLION threads on CAI's... which is part of the issue. I spent about 7 hours last night reading through them and I am farther from my answer than before I started... there is so much controversy and each thread is the opposite of the one I read before.
TL;DR: Which CAI route to take?
- AEM
- JWC
- Just add a new filter to stock MCS
- AEM
- JWC
Next steps I'm leaning toward are intercooler and JB+ so didn't know with those planned down the line if the CAI was something I should also upgrade.
Originally Posted by [B
cerenkov][/B] Since you don't care about sound stick with stock, it's a good setup. Save the money for something else.
Another system is DOS but it is only available on the used market
Makes sense... wasn't sure what the increase would be from JCW over the MCS intake as I know it's got a larger box and more free flowing filter I believe.
The JCW filter is arranged as a cone (similar to the traditional K&N design), so the expected lifespan would be longer - more surface area to cover up with dirt before you need replacement. But unless you increase boost beyond the limit of airflow sported by MCS's rectangular, I doubt you will see any peformance improvement. For that, you would need to install a K&N filter inside the JCW fully shielded intake box!
http://www.detroittuned.com/forge-al...r-intercooler/
a
Makes perfect sense. This is the info I'm after. So according to your statement, you might suggest going with the JCW air intake unit, then swap the filter itself inside for a K&N filter? That seems like it would net the most benefits.
Again I understand a CAI isn't going to get me much HP gain. I'm wanting to future proof myself and keep good air flow for future upgrades (inter cooler and tune to start).
Any idea what this set up would sound like? I've had a Evo XIII with ~475 whp stage 3. While the blow off noise is intoxicating at 16, I'm now 30. A real loud drone gets old. This is my daily driver as well.
I'm after practical, ACTUAL useful mods. Wanting to start off slow to get my feet wet again and burn off the rest of my warranty.
I think I want to avoid any open air box system as I feel it'll be to droning as well as the fact that it's not a true cold air intake.
Thanks again. Fantastic info so far.
No change in airflow, as the JCW filter uses the same paper element. The actual airflow rate supported by both would be the same.
Intercooler is a required upgrade if you intend to autoX your car, or drive it with purpose. Stock intercooler gets heat soaked after the first autoX run, it power goes downhill from there. I have installed Alta's FMIC and love it, but today you can do even better with Forge's unit:
a
a
An EVO XIII?! Wow you have connections!
Ok smarta$sness aside, JCW intake with K&N filter, FMIC, Tune (the N18 has minimal options for this right now), & exhaust. Bam! Your done with engine mods for the casual tuner.
Next step, suspension. Then the brakes. Then the body. Wheels should go in there somewhere. Of course this is a slow process So you'll get there when you get there.
HAHA.... VIII.
Thanks for the input. I have 30k miles to burn for my warranty so I'm in no rush.
Any idea on sound for that CAI setup?
The DOS system used a cone filter with a mostly close system. The opening was attached to the bulkhead via a hole that is drilled in. (it sounds worse than it actually is) Other than the stock systems this is closest to a 'closed' system. Unfortunately this system is no longer made and you'll have to scorge the markets to ever find one.
The next best thing is the AEM and DDM intakes. Truthfully, unless you're going to get a proper tune (again this is difficult right now for the N18 engine) then I would just get the JCW intake, it'll be the best intake for your setup.
honestly i would just get a good cone filter. i run an amsoil filter on my evo, and i would on my mini if i were upgrading it. not tremendous amounts of differences, just get one that still filters well.
i actually disagree with needing an intercooler upgrade for autox. track, yes, autox no. you drive for 40-70s, and then the car sits for 5-10minutes and normally you (should) spray your intercooler down then anyway
exactly. i actually swapped from an upgraded intercooler to stock since i only autox my evo - preferred the weight savings.
I'll prob upgrade the inter cooler as well down the road as I have had an overheat issue before and I'm a tad paranoid haha.
I'm confused...according to RealOEM all N18 (S and JCW) share the same part number for the air filters and the air box itself. And they are panel style and not cones.
S:
http://www.realoem.com/bmw/showparts...12&hg=13&fg=20
JCW:
S:
JCW:
S:
JCW:
S:
JCW:
This kit uses a cone filter and had a larger airbox. It's a true cold air intake as it's a closed system. You won't get the "cool" (I use that very lightly) blow off sound from the kit but it's truly cold air and not sucking the engines hot air like an open system.
To my knowledge they are low in supply currently and run $291 thru the dealer.
07-16-2020 12:54 PM
polotska
08-23-2015 03:03 PM
Getrieben
08-15-2015 09:09 PM
