Navigation & Audio NEWB question -- antenna power
Hi,
I just received my PioneerMVH-X560BT from Crutchfield. The kit has the blue and white system controlled remote taped off, but the connector wires it comes with has a blue wire waiting, labeled for "Power Antenna"
My search shows that while we don't have a power antenna, we do have a booster that needs power. And this blue-white wire in the guide reads "Connect to system control terminal of the power amp or auto-antenna relay control terminal" so can I just connect these?
Also, anyone know which side is the hot side of fuse 10? Thanks!
-JM
-JM
Hi,
-JM
-JM
It looks like you're already installed, but yeah, I discovered the hard way that the power antenna cable should be connected to the receiver wire that would theoretically run to an amp. Otherwise, no a.m. reception.
And on my install yesterday, I learned the right side of the fuse is the protected side, and the left unprotected.
While true, this is the thinking that got me burned yesterday. It turns out some head units (like the JVC I installed) need the power antenna line hooked up to get A.M. reception, despite the fact that our MINIs do not have power antennas. So, be advised!
Correct in the notion that am is picked up by the antenna amplifier and will not be picked up unless it is powered up by the power antenna wire
07-16-2020 12:54 PM
2011cooperSconvertible
R57 :: Cabrio Talk (2009+)
04-01-2019 06:03 AM
R50/53 R53 Chrono Pack - gauge?
missinmyjeep
08-22-2015 07:13 PM
