MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > JCW Garage
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
new mini owner
19 Replies, 203 Views
Advertisement
Thread Tools Search this Thread
Old 10-02-2007, 08:41 PM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI ADAMSALTAMINI is offline
Vendor
Send a message via AIM to ADAMSALTAMINI
Gallery
ALTA / JCW shift indicator DIY for the R53/GP
folks, well Giusseppe was dying to get some mods to match his stablemate Howard! So one of the first things was the JCW shift indicator! Now at first this may seem like a simple task, but if you have looked at what JCW offers for the R53, you will see the problem. It is a dash mounted single sided indicator, that looks like dog-doo-doo vs. the R56 version that mounts on the column. SOOOOOO not content to stay with the norm, I decided to mount the R56 version on the R53 column. Here we go!
First call ALTA or go online to www.altaminiperformance.com and order up the JCW R56 Shift Indicator. Then indicate you have an R53 and you get the proper instructions, hardware etc. to match.
Second, when the package arrives you will get the indicator mounted on top of the R56 column plate. To begin, hack this piece apart. (I know sounds rough! Don’t be scared!) Remove the two screws that secure the indicator to the plate. Then pull the indicator away from the plate.
Then do this:
I used a set of dykes to simply open up a slot in the plate to release the wire.
Now, with the JCW indicator free from the clutches of the R56 plate, grab a set of wire cutters or similar and carefully cut a small slot in the side of the tube that protrudes from the bottom of the indicator. The slot is necessary to allow the wire to fold over instead of go down. (So this makes more sense, the end of this grey wire has a LARGE plug on it. As a result you can’t feed the wiring through the R53 plate. Instead we will run the wire under the indicator, then under the OEM tach or tach/speedo combo.) See photo below.
Disconnect the battery.
Remove the tach (or tach/speedo combo) from the column plate cover in your R53. Then remove the plate.
Now using the R56 plate as a guide, mark two small holes to be drilled into the R53 plate. (Don’t make these too big!!!!!) Then use the screws removed above to mount the indicator to the plate. And it will look like this photo below (note the new ALTA Gauge Pod/Gauge combo mounted as well!)
Ok! Now remove the lower knee protection panel from under the steering column. It has two small screws and two rather sturdy pop-it type fasteners at the top. PULL HARD!
This allows for mounting of the white control box for the indicator. Using the supplied wire ties strap it to the substructure under the dash.
Finally, locate the OBDII data port under the dash. Release it from the mount to get better access to the wiring leading away from it.
Using the ‘T-taps’ provided by ALTA, tap the following wires:
Green with Blue Stripe
Brown
White with Red Stripe.
Then using the supplied male ends supplied by ALTA connect the three wires leading away from the control box to the following:
Green wire on Indicator goes to Green with Blue Stripe
Brown to Brown
White to White with Red Stripe.
Using the BMW instructions flip the dip switches in the control box to 4-cyl, then choose a redline point. These are variable. On the GP I chose 7000 RPM.
Then re-install the top plate, tach etc. Re-connect battery.
Start engine. If the indicator is working, it will flash etc., then leave one green LED illuminated in the center.
Then steadily bring the RPM up toward the redline chosen to watch how the lights move from the inside out.
For a YouTube video go to ALTAminiperformance.com click on JCW OEM parts, then the indicator, then on videos.
Double check that everything is re-connected and bolted tight and enjoy!
Thanks!
Adam
ALTA MINI Performance
adam@altaminiperformance.com
NAM Handle ADAMSALTAMINI
FOR PHOTOS CLICK THE LINK FOR THE .PDF BELOW!
Adam Taft: CEO ALTA Performance™
503.693.1702 Ex. 110
WWW.ALTAPERFORMANCE.COM
WebsiteBlogYoutubeFaceBookE-mailAIM
Old 10-03-2007, 01:05 PM
JCW Driver's Avatar
JCW Driver JCW Driver is offline
Gallery
Having seen this in person this weekend, I have to say a huge thumbs up. It really is cool.
Old 10-30-2007, 12:06 AM
Edge Edge is offline
AdMINIstrator
Send a message via ICQ to Edge Send a message via AIM to Edge Send a message via MSN to Edge Send a message via Yahoo to Edge Send a message via Skype™ to Edge
Gallery
VERY nice... at MOTD, I asked the MINIUSA guy about the new JCW shift light indicator, and whether it would also be released to support the 1st Gen MINIs. He said no... R56 only. That ticked me off.
My only concern (in my typical paranoid self) is that the fact it taps wires might affect the factory warranty, as it is not officially supported on the R53... so I might not get it yet, but I definitely see one in my MINI's future (14,000 miles left on warranty!).
Way to go Adam! The original JCW shift light looks like crap... this is SO much better.
"Mr. OEM" - 05 JCW (TK, GPIC, SS, GPTA, R56 RSB, StBr, SpBr, GPWhls, SV, RS, R56 GSI, IES, StrWhl, GK, HG, LBIT) MCS, HB/HB, Packs: 1, 2, 3 & 4. LSD, Rear FL, LB/PB upholstery (inc. LB SB & HB), HB Int, Anth. HL, PDC, Nav. OEM: DPSM+Aux, SIRIUS, BT, RV Cam, Aux gauges, ILK, Alarm, AK, PFM, DL, SpLnk, CFD, CSL, BIW, R52 diag rods, EuroTL, EuroWT, EPS, EASM. AM: IanCullAUC, Intravee+KCA420i, SchrothR4, MM-STR.
License Plate: SUV2BIG MotoringID: CARVE129 H/K -> DPSM thread - 11 months, 12 days. WHEW!
Old 10-30-2007, 07:39 AM
ALTAPerformance ALTAPerformance is offline
Vendor
Gallery
Thanks for the compliments! I truly don't expect ANY warranty concerns as it uses an OEM JCW part, and only taps into signals. For warranty issues the lead must be cut, not tapped. PLEASE let me know if I can ever help further! Thanks again! adam@altaminiperformance.com
Sales and Customer Service
ALTA™ Performance
503-693-1702
sales@altaperformance.com
www.altaperformance.com
Old 11-28-2007, 03:40 PM
Hwydsgnr's Avatar
Hwydsgnr Hwydsgnr is offline
Gallery
I just ordered the JCW R56 shift lights from Alta for my R53 (Xmas present from my wife).
Just wondering if the cable from the lights is still visible as you run the wire under the tach?
I have the factory boost/volt gauge cluster that has a new top plate/gauge pod and there doesn't appear to be enough room to slide the wire under the tach.
Any way to remove and then reattach the plug?
Can you cut the wire and splice (connectors or solder)?
Ever think of mounting them on the blank atop the dash for the solar sensor (for those of use without auto A/C) and running the wire down to OBD port from there?
06 MCS SB/S, Checkmate, Helix 15%, RMW Tune 201WHP 189Ft-Lb, LSD, JCW Intake, JCW Exhaust, JCW Sport Brakes, JCW Plugs, JCW 380s, Goodyear Eagle F1 A/S 205/45/17, M7 SRP, Whalen Shift Machine, MMC#270
Old 11-28-2007, 03:48 PM
Vendor
Gallery
Thank you for asking. I replied to your mail today as well:
Thank you for asking. The answer is both yes and no. VERY small amount of it is shown (like less then 1/4") I don't see how the wire could be removed from the plug, UNLESS you wanted to cut and splice (which could be done for sure.)
Hope that helps! Thanks again for your purchase and christmas coming early!
Adam Taft
3111 NE Shute Rd.
Hillsboro, OR 97124
503-693-1702 voice
503-693-1782 fax
ALTA™ Performance
503-693-1702
Old 11-29-2007, 12:00 PM
pbraun's Avatar
pbraun pbraun is offline
Gallery
Put one on my GP a few weeks ago, and I love it! An additional bonus is that you can increase the red line to 7250 if you want! I did! great!
http://peterbraunblog.wordpress.com/
New House progress: done! find me on flickr
Old 11-29-2007, 12:36 PM
Vendor
Gallery
Glad you like it!
Thanks for the feedback here!
ALTA™ Performance
503-693-1702
Old 11-29-2007, 01:08 PM
Motor On's Avatar
Motor On Motor On is offline
Community Servant
Gallery
Garage
instead of typing how about I just show you how it looks?
PHOTOS
NOTE: I could havemounted it further back for even less visibility of thewire but as personal preferance I wanted it flush with the fron of the fascia
-Drew MMC#282
Follow NAM on Facebook
Old 11-29-2007, 01:56 PM
Eric_Rowland's Avatar
Eric_Rowland Eric_Rowland is offline
Gallery
Nice music selection!
'04 IB/W MCS w/all the goodies, Ian's auto-up/GDO, MMC#I69/MID CURV169; power folding mirrors
"You can't save the world unless you're willing to make other people sacrifice." - Dogbert, via Pendergast
Old 11-29-2007, 03:39 PM
JCW Driver's Avatar
Gallery
Exceptionally cool mod. (makes a note to Santa Claus....)
Old 11-29-2007, 05:16 PM
Hwydsgnr's Avatar
Gallery
Thanks Motor On for the photos.
After my post I actually did find your photos and printed them out for reference.
Since this is an Xmas present I will have to wait until January for the install. It will make a good winter project for the garage.
Old 11-29-2007, 05:43 PM
Motor On's Avatar
Community Servant
Gallery
Garage
Err I did it in 45min toan hour with a pocket knife, with proper tools it's about a 15-20 min job.
-Drew MMC#282
Old 11-29-2007, 05:47 PM
Vendor
Gallery
EXCELLENT point!
ALTA™ Performance
503-693-1702
Hwydsgnr's Avatar
Gallery
May need to cut and resplice the wires and hide them totally under the top plate.
Old 11-29-2007, 06:19 PM
garylimey garylimey is offline
Gallery
Dito, will it all fit
Old 11-29-2007, 06:30 PM
Vendor
Gallery
I BELIEVE it will certainly work. MIGHT have to cut the wires and splice instead and then drill a hole, vs. tucking the wires.
Call me if you are lost.
Thanks again!
ALTA™ Performance
503-693-1702
Old 11-30-2007, 03:55 PM
Hwydsgnr's Avatar
Gallery
Quote:
That's what I'll probably do.
Also been thinking of mounting them on the on top of the dash where the the solar sensor blank (round buttom for those without auto a/c) is and running the wire down to the OBD port from there. May look nice above the dash.
I will need to check the curve on the bottom of the lights vs. the rear dash top once I get it apart.
Old 12-19-2007, 04:22 PM
Vendor
Gallery
How did it go? What did you find out?
Old 12-21-2007, 03:16 PM
Hwydsgnr's Avatar
Gallery
See post #12. It's a Xmas present. Maybe next weekend I'll give it a shot.
Will definitely post pictures.
Any idea of the wire gauge I will be tapping into and splicing?
Last edited by Hwydsgnr; 12-21-2007 at 03:57 PM. Reason: Add question on wire gauge
Old 12-21-2007, 05:36 PM
Vendor
Gallery
Ok I am an idiot! I am sorry!
It is like 14/16 gauge wire.
Thanks again!
Old 12-25-2007, 06:22 PM
MUShadd MUShadd is offline
Send a message via ICQ to MUShadd Send a message via AIM to MUShadd Send a message via Yahoo to MUShadd
Gallery
My GF ordered one of these for me, but I doubt she disclosed that I have an R53. The instructions included were for an R56, are there any specific parts that I should check for to see if I got the correct version?
Old 12-25-2007, 06:43 PM
Motor On's Avatar
Community Servant
Gallery
Garage
Quote:
If it came on a stering colum panel its the R56 part, it should have the junction box, as long as your wires are right you'll be all set, I never had to indicate anything when I ordered mine. Hopefully ALTA can confirm this before hand, if not I'd wait a couple of days and give them a phone call.
(BTW-GF who supports mods )
-Drew MMC#282
Old 12-25-2007, 06:57 PM
newbs49 newbs49 is offline
Gallery
SnYpR
You have to take the indicator off the R56 panel and mount it on your panel.
Adam has instructions to do this. He did this to his GP, and I believe Pbraun has also.
Old 12-25-2007, 08:09 PM
Hwydsgnr's Avatar
Gallery
Just unpacked the shifts lights and made a template of the bottom of the indicators to match against my top plate with the OEM boost/volt gauges.
Looks like the two curves don't match with the top plate having a sharper curve.
Anyone else notice this on your R53 installs with the standard top plate?
From the other install photos I have seen on the standard top plate, it appears to match very well.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
