Interior/Exterior Dash Command on my dash
Old 03-27-2015, 12:48 AM
suntaepark's Avatar
suntaepark
suntaepark is offline
I downloaded the dash command app on my tablet, and hooked it up on my screen. it is pretty cool...
Old 03-27-2015, 05:55 AM
Grizld700's Avatar
Grizld700
Grizld700 is offline
Nice!
Old 03-27-2015, 06:55 AM
rckrzy1's Avatar
rckrzy1
rckrzy1 is offline
yep, run mine all the time, just got a LG 4.5" phone for $30 and just use the BT function, damn cheap gauge set and you can customize any way you want.
Old 03-27-2015, 09:20 AM
bavmotors's Avatar
bavmotors
bavmotors is offline
Is there anyway to get it to turn on and connect automatically?
Old 03-27-2015, 07:54 PM
05r50's Avatar
05r50
05r50 is offline
With Android you can use an app called Tasker and set conditions and responses. So you can auto start an app when 12v is supplied if you keep it plugged into the cig lighter.
I haven't found an iOS app that does this.
Old 03-27-2015, 08:17 PM
neonsteve's Avatar
neonsteve
neonsteve is offline
That's sweet. I might have to do that with an old Android phone I've got. Ive already been using Torque.
Old 03-27-2015, 11:28 PM
suntaepark's Avatar
suntaepark
my iPhone will not display on the monitor, so I ended up purchasing an used android tablet for 50 dollars on cowboom.com lol.
Old 03-27-2015, 11:29 PM
suntaepark's Avatar
suntaepark
thats good to know.
Old 03-28-2015, 03:39 AM
cerenkov's Avatar
cerenkov
cerenkov is offline
Mine is "permanently" mounted. Because it is plugged into a 12v ignition source the phone turns on when I start the car. All I have to do is "slide to unlock" and dashcommand is already open and it automatically connects. It is usually fully connected and running before I'm out of my driveway.
I would be nice to have it 100% automatic and if Apple ever allows something like the android Tasker app that would be great.
Here's a picture, I've gotten rid of the orange back-lighting and one day I'll get a fabricator to customize it so that it looks more factory. The hard part is finding someone.
Old 03-28-2015, 06:48 AM
bratling's Avatar
bratling
bratling is offline
Super Moderator
Apple doesn't allow apps that kind of access.
BUT, if you jailbreak your device, you can use Activator from Cydia to start/stop pretty much anything on power on, power off, and many other triggers, including a long list of gestures. Long before apple had Control Center, jail breakers had the same functionality via Activator.
If your device isn't currently jailbroken, you will have to wait for a new set of exploits to be weaponized. Apple isn't signing any of the vulnerable iOS versions anymore, so you'll have to wait until exploits are found in the current or upcoming versions of iOS. With the Apple Watch around the corner, and iOS updates coming to support it, I expect that even if there are weaponized exploits ready to go, the usual jailbreak creators will wait for those iOS updates to be final so they don't burn exploits by making it possible for Apple to fix them early.
It's a classic cat and mouse game.
PelicanParts.com
05-21-2023 04:51 AM
PelicanParts.com
Accessory Products
10-01-2015 01:23 PM
10-01-2015 12:34 PM
10-01-2015 12:34 PM
10-01-2015 12:13 PM
Quick Reply: Interior/Exterior Dash Command on my dash
