Electrical Interior Light Problem
Yesterday I noticed that the dome light and underdash lights in my car stopped working. But the reading lights still work properly. I had my car in the shop today so they looked at it and didn't know what the problem was. And it isn't the fuse. Does anyone know a way to fix this? It is a little annoying not having any light in my car at night.
Kyle
Kyle
Assuming that your lights weren't disabled...
People have reported LED failures with surprising regularity. Did they all go out at the same time, or could they have been going out and you only noticed when the final bulb went out? If your boot light is working, see what happens if you swap the bulbs between the dome and the boot.
LEDs add so little electrical load that they should not be a problem to run in parallel with the regular bulbs. However, to diagnose this problem it would be better to disconnect them and run a completely stock configuration to remove any variables. Here is how the MINI is wired:
These lights are connected on the same circuit:
reading lights (front & rear)
vanity mirror lights
glovebox light
These are on a different circuit:
footwell lights
dome light
The boot light is on its own separate circuit.
By different "circuits" I mean separate power outputs from the BC1 computer. The fuse for all interior lighting is F14. Your symptoms are unusual and I'm not sure what to recommend. It's possible that your BC1 computer is at fault (hope you are still under warranty).
glovebox light
footwell lights
dome light
07-16-2020 12:54 PM
phrza81
10-10-2015 11:37 PM
nismo4life
08-05-2015 08:31 AM
