Happy with your 215-45/17 non RFs?
To anyone who went with 215-45/17 when they switched to non RFs... Any regrets? Would you do it again?
Most of what I've read has been positive about the slightly taller size.
Except this:
My main objectives are:
1) Improve comfort
2) Sacrifice handling only at outer limits
3) Reduce tire noise
Except this:
1) Improve comfort
I too have 215/45/17 and have no complaints. Will probably do the same for my next set of tires.
I just did the switch. Things i notice is less road noise #1.
Bumps and cracks in the road are less intrusive. The major trade off
is steering responds, not nearly as good as the run flats.
My mini tends to drift more and feels less responsive. Cornering is also
not as crisp and tight. I have the yok's ES100's and reaaly miss the
RF handling. But it does offer a smoother ride... my 2cents
very happy with mine... it fills out the fender gap with a slight lowering allows a very clean look... though if you lower, offset becomes limited even if its just a small increase in tire size from oem
i had 2 sets of 215/45-17 now for the summer, and 1 for winter, and im going to get a third set soon
I used 215/45 after using 205/45 non runflats on my previous MCS. For your objectives they fit almost 100%. The car does not feel as nimble or respond as quickly as a lower profile/skinnier tire. But the grip is great.
Done em both..
for day to day stuff, the 215/45 is a nice combo. For ultimate handling, the 215/40 is a bit better, but ride starts to suffer, and you better watch your pressures like a hawk! It's easy to pinch the sidewall.....
Matt
Matt
I found them softer...
it's the sidewall, the the runflats are stiff. But I can't overstress how important pressure is on this size. When you hit a big bump, even though the ride is softer, the whack can be harder as there isn't as much sidewall to compress before you're hitting the rim.
Matt
Matt
Alpha Motoring
Sep 7, 2020 07:34 PM
Navigation & Audio USB stick keeps repeating same folder
Wombat Pie
Navigation/Audio
Oct 5, 2015 08:00 PM
EVMini
Sep 28, 2015 10:20 AM
Clubber_Lang
Sep 23, 2015 03:43 PM
