Odd rear pad wear
Old Jan 2, 2007 | 02:44 PM
mangotangoe's Avatar
mangotangoe
Odd rear pad wear
Just installed the caliper stiffeners (bushings) in my rear calipers. After a recent rain and subsequent surface rust on the rotor, I can see that the rear pads are not in full contact with the rotor. I can see that there is approx. 1/4 inch of swept area, toward the hub that is now not in use. I would guess that this is due to uneven pad wear due to the deflection of the caliper/with the rubber bushings. (didn't look at the backside of the rotor)
Question, besides replacing the pads (only a few months old) is there anything that I can do. Or, just let it fix itself over time?
Old Jan 2, 2007 | 06:04 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
go to midas
Old Jan 2, 2007 | 06:22 PM
Hound_va's Avatar
Hound_va
Remove the pads and have them resurfaced paralllel to the backings, and give up brake pad life equal to the amount which would need to be removed to get the surface parallel. Or let them wear in to their new wear pattern. Depending on the pad, I'd expect that to wear in pretty quickly.
Toolman
Jan 20, 2016 06:50 AM
squawSkiBum
Oct 2, 2015 09:21 AM
jpgwinn24
Tires, Wheels, & Brakes
Aug 23, 2015 02:53 PM
jpgwinn24
R55 :: Clubman Talk (2008+)
Aug 20, 2015 06:57 PM
