Brake Wear Sensor Light
Old Dec 22, 2006 | 08:54 AM
StillK's Avatar
StillK
Just replaced front and rear pads - had the front rotors turned - new rotors rear (salty NE roads took a tole on the rears) and new sensors. The sensor light is still on - tried resetting the tire pressure warning switch - turned key to #2 position for 30 seconds - no change. Any ideas? Brakes work well no chatter - good pedal feel etc.
Old Dec 22, 2006 | 09:17 AM
FUEGO's Avatar
FUEGO
Are you using OEM pads? Did you replace the wear sensor cable? The sensor is a consumable item which means that once the pad wears down, the sensor is basically opened up by rubbing/wear against the rotor which turms on the LED. It must be replaced to get the sensor LED to turn off..
Old Dec 22, 2006 | 11:11 AM
StillK's Avatar
StillK
Brake Sensor Light
Fuego
No the pads were not OEM - I think they were Mentex - not sure - but they were sensor compatible. Yes as per my previous post - the sensors were both replaced.
Old May 8, 2007 | 10:28 AM
norm03s's Avatar
norm03s
I can't reset the warning light either
I have good sensors front and rear or so I thought. I need to check them for continuity next.
Old May 10, 2007 | 05:03 PM
JCWGrover's Avatar
JCWGrover
Just replaced my pads, and sensors, light is still on!! any answers?
Old May 10, 2007 | 05:06 PM
not-so-rednwhitecooper
disconnect battery, allow ecu to reset.
Old May 10, 2007 | 06:30 PM
JCWGrover's Avatar
JCWGrover
That worked
Old May 20, 2007 | 02:31 PM
norm03s's Avatar
norm03s
This should be a sticky
That worked, needed to clean out the boot anyway. After I made a shorted sensor wire out of an old one and plugged it into the rear, still had the light.
Thanks to not-so-rednwhitecooper
Old May 20, 2007 | 06:40 PM
fentos's Avatar
fentos
Installed new pads this weekend as well and was running into the same problem. I will try resetting the ECU in the morning. Thanks for the advice!
Old Jun 29, 2007 | 08:57 PM
Glad to help guys.
Old Jan 14, 2010 | 06:36 PM
bmraha's Avatar
bmraha
I just replaced my pads and sensors. The light was still on after that.
Then, I reset the ECU by disconnecting the battery and the light went off.
But in the evening, the light is on again
I am using OEM pads.
Can someone help?
Old Jan 15, 2010 | 11:25 PM
RedTexasMINI's Avatar
RedTexasMINI
Put your key in the ignition turn it to the 2nd position, leave it there for about 30 seconds and the light should turn off, this worked for me when i got my pads and sensors replaced.
Old Jan 16, 2010 | 01:11 AM
yellowbritishrocket's Avatar
yellowbritishrocket
if all of these ideas dont work unplug the sensor wires from the sockets and check the connections to make sure there is no grime or anything in the plug...trust me it can get even in that plug ive had to use a can of compressed air on them before
Toolman
Jan 20, 2016 06:50 AM
JPMontes3
Aug 23, 2015 01:26 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
