When should I rotae my tires?
Old Apr 3, 2003 | 02:20 PM
MiniMo's Avatar
MiniMo
I have the eufori@ run flats with 6K miles on them. When should I rotate and which way? Front to back? Clockwise?
Thanks,
Steve
Old Apr 4, 2003 | 08:30 AM
Alex@tirerack's Avatar
Alex@tirerack
Every 5k or so, take rears up to the fronts and cross the fronts to the rear.
Alex
>>Thanks,
>>Steve
Old May 15, 2003 | 09:19 PM
zgokart's Avatar
zgokart
>>Alex
___________________
Not sure if I understand whether by "crossing front to the rear" you mean to put the front tires on the same side rear or diagonally to the other side rear. Also, does this apply to assymetrical tires which I have?
Old May 16, 2003 | 07:24 AM
Alex@tirerack
Rotation diagrams
Alex
Old May 16, 2003 | 07:30 AM
Antranik's Avatar
Antranik
>>Thanks,
>>Steve
I just passed 5k miles on my car and I've waited too long. With proper air pressures the entire time and dozens of fun-runs, the rear look like new while the front is quite worn out. These are with the Dunlop Runflats.
Old May 19, 2003 | 01:38 PM
Danbo's Avatar
Danbo
>>Thanks,
>>Steve
I use to be a mechanic, but still swear that its a very very good idea to rotate your tires to front to back on the same side of the car. I say this because you could get steel belt separation in the tire witch will nock out your balance. I rotated my tires the first time AND hand torque them at 2000 miles.
zdw2082
Oct 5, 2015 09:59 AM
dpike
Sep 12, 2015 08:19 AM
Tires, Wheels & Brakes
Sep 9, 2015 11:08 AM
Ntety
Sep 2, 2015 08:39 PM
