Lug remover...
Old Apr 7, 2006 | 12:13 PM
coopercrazy's Avatar
coopercrazy
Lug remover...
Is there and adapter I could get for my cordless drill so I can change my wheels easily? Or what tools are others using to swap rims out?
Old Apr 7, 2006 | 12:35 PM
Mineon's Avatar
Mineon
I used a cordless drill and socket adapter for several years to make wheel changes go quicker at autocrosses, but my wife got me a Dewalt cordless impact for my birthday a couple of years ago, and that works even better. You'll still need a breaker bar (or the stock lug wrench) to loosen the lugs and a torque wrench for tightening them down, but a drill-socket adapter can make the job go a lot quicker. The 1/4" hex to 3/8" or 1/2" square (socket) drive adapters are about $5 at any hardware store.
-Keith
Old Apr 7, 2006 | 12:44 PM
coopercrazy
What do they need to be torqued down to?
Do you think this is a waste of $$?
http://www.jcwhitney.com/autoparts/P...+impact+wrench
Old Apr 7, 2006 | 01:09 PM
Mineon's Avatar
Mineon
I'm not sure what the factory service manual calls for, I usually torque mine down to 90-95 ft-lbs with a torque wrench.
If you already have a decent cordless drill, it would likely be a lot better for swapping tires than that JC Whitney cheapie 12V impact. You'd still probably need to use a breaker bar to loosen the lugs, and you'd definitely need a torque wrench to tighten them.
-Keith
Old Apr 7, 2006 | 02:01 PM
mielnicki's Avatar
mielnicki
Get yourself a 4-way lug wrench. I can take off all four lug nuts faster than an impact driver.
Steve
Old Apr 7, 2006 | 02:06 PM
coopercrazy
Thanks guys!!!
Old Apr 7, 2006 | 02:26 PM
kenchan's Avatar
kenchan
i just use a sears long handle 1/2" drive ratchet. you can use it to
loosen the lug (without a breaker bar) and then fold the neck so you
can turn the lugs while holding the ratchet straight toward the lug without
any ratchet action. very fast.
Old Apr 7, 2006 | 02:29 PM
Mineon's Avatar
Mineon
Steve
Really? I can remove all four of mine in 30 seconds or less with my cordless impact driver. You must be really quick
Old Apr 7, 2006 | 04:57 PM
mielnicki's Avatar
mielnicki
I can change two tires, including jacking up the car in about 5 minutes.
Steve
Old Apr 7, 2006 | 05:04 PM
Motor On's Avatar
Motor On
You can use a cordless drill or an air gun (really quick) and you'll need a drive adapter for the cordless availible at the hardware stores. I torque mine to 101 Nm and out of sixteen lugs I've had one loosen an 1/8 turn in three weeks of driving and track day combined, at least once a week I go around the car and check all my tire pressures and tourque the lugs. It still takes me 5 min to get the car jacked up (I need a new jack soon) but I can do four tires (less the jacking time) in about 2-3min with just the torque wrench. I imagine an impact wrench would cut that down to 45sec-1min.
Old Apr 7, 2006 | 05:39 PM
Mineon's Avatar
Mineon
Steve
Not bad My average time for swapping all four wheels/tires at an autocross is 10 minutes (from start to finish, including jacking), but I've been known to do it in 8-9 minutes if bad weather was threatening. A stud conversion would take another minute or so off my times (wouldn't have to line up the holes), and if I'm in a real hurry, I'll just torque them with my cordless impact driver (it takes them to 80-90 ft-lbs) instead of a torque wrench, that saves me another minute or so. I used to not worry about using a torque wrench to torque them to spec, and if you skip that step, you can use a 4-way lug wrench to loosen, remove, and tighten the lugs.
-Keith
Old Apr 7, 2006 | 08:31 PM
gowest's Avatar
gowest
Jeez guys, slow down and smell the rubber.
Old Apr 8, 2006 | 04:21 AM
Aqualung's Avatar
Aqualung
92 lbs is what I've seen here and what I do.
freckles81
Jan 15, 2017 06:33 AM
theblackfalcon
Oct 19, 2015 05:22 AM
Sep 18, 2015 12:45 PM
papawhiskey
Sep 14, 2015 05:47 PM
Sep 14, 2015 12:48 PM
