Rear Brake bleeders
Old Mar 22, 2006 | 12:52 PM
Matthew's Avatar
Matthew
Rear Brake bleeders
Hey guys,
I have to bleed the brakes on my 1974 mini cooper, but the only problem is the rear bleeders are extremly small and kinda rusted. I was wondering if you guys knew where i could purchase some incase they shatter while i try to bleed the brakes.
Thanks in advance
Matthew Rathbun
Old Mar 23, 2006 | 05:15 AM
polmear's Avatar
polmear
check with a local import parts specialist. unless you're in GB, then check witih a local parts specialist.
would really help if you listed a location
should be a pretty common part, though
Old Mar 23, 2006 | 05:44 AM
toddtce's Avatar
toddtce
Mini Mania perhaps, they deal heavily in the 'Classic Mini' where many here are working the new MINI. Feel free to pull up a chair and hang around however.
Old Mar 23, 2006 | 06:19 AM
BFG9000's Avatar
BFG9000
See if anyone makes the "speed bleeder" type in your size. They have a check valve in them so you can bleed the brakes alone: http://www.speedbleeder.com/size.htm
http://www.russellperformance.com/au...d_bleeders.htm
Old Mar 23, 2006 | 12:39 PM
Matthew's Avatar
Matthew
Hey guys,
thanks for the reply and the links guys. I'm kinda new to the whole restoring car bit, I'm only 18. the speed bleeders look intresting, I don't know if I would get them they seem a bit much for just bleeders.
bjcarter2
Aug 31, 2015 04:03 PM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
jpgwinn24
Tires, Wheels, & Brakes
Aug 23, 2015 02:53 PM
jpgwinn24
R55 :: Clubman Talk (2008+)
Aug 20, 2015 06:57 PM
