Longer wheel studs
Old Mar 17, 2006 | 11:29 AM
Eastsidemini's Avatar
Eastsidemini
Longer wheel studs
I am searching for 75mm coated tensile steel studs. 12mm x 1.5. Tuner is currently out of stock but that's the exact ones I'm looking for Anyone knows of any other place? Also planning to use longer and lighter tuner style lug nuts.
Old Mar 17, 2006 | 01:00 PM
onasled's Avatar
onasled
http://www.bimmerworld.com/
Look under wheels
Old Mar 17, 2006 | 01:23 PM
Eastsidemini
Look under wheels
Thank you Onasled
Old Mar 17, 2006 | 01:26 PM
shaun5's Avatar
shaun5
If you are not in a big hurry, I'm going to make some plain (no hex key / bullnose) ISO 10.9 studs. 13mm threaded x 14mm unthreaded x 30mm (or whatever).
Old Mar 17, 2006 | 01:30 PM
Eastsidemini
Thanks for the info. But I do need it asap cause the track event is a week away. Keep us update on you progress.
Old Mar 17, 2006 | 01:50 PM
shaun5's Avatar
shaun5
Ya, I would need probably two weeks...
Old Mar 17, 2006 | 02:03 PM
AZMCS's Avatar
AZMCS
http://www.tcklineracing.com/wheelstud.htm
I have these from TC Kline. Extremely high quality and what our local dealership uses on their spec cars. They don't do the "ultra-coated" ones. Use the standard "Nascar" ones. I know, NASCAR, on a MINI. Don't worry they go on M5's as well!
Old Mar 17, 2006 | 02:41 PM
shaun5's Avatar
shaun5
At 9.95 each, let me know what you want exactly...
Old Mar 17, 2006 | 09:22 PM
Eastsidemini
What are your's made out of? Any pic and spec? Is always nice to know someone can fabricate it. But not at $9.95.
Old Mar 18, 2006 | 06:38 PM
shaun5's Avatar
shaun5
I haven't made any yet, so my specs are open. The TC Kline studs in 4140 are probably heat treated to grade 8 (very close to 10.9). You can read my post above for what I was planning on making, but I can make a few variations, if there is interest. If I only make a few, they will be cut thread vs. roll thread. Regardless of number made, these will NOT be a backyard / shop project and WILL have FULL material and strength test documentation.
MINI VINI
Oct 13, 2015 08:57 AM
rckrzy1
Aug 26, 2015 09:12 AM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
bradstyle
Aug 21, 2015 11:43 AM
jcb-memphis
Aug 8, 2015 11:09 AM
