BBS-RGF with H Sport Springs
Old Feb 28, 2006 | 08:52 AM
rwalkerphl's Avatar
rwalkerphl
Hi All,
I just picked up a set of 16 inch BBS (+35 offset) wheels with Yoko AVS100s (205-50-16s). It was mentioned to me that the wheels may rub slightly. This may be more so as I am on H Sport springs...
Is there any way I can avoid this? If there is what can I do?!
Thanks,
Robin.
Old Feb 28, 2006 | 09:15 AM
Passat774's Avatar
Passat774
Yeah, let me have the wheels for my car and they will never rub
Old Feb 28, 2006 | 07:30 PM
sprp85's Avatar
sprp85
Originally Posted by rwalkerphl
Hi All,
Thanks,
Robin.
et35 + 205/50 + hsport..
hm I'm pretty sure they will rub..
I have et35 with 205/40/17s stock height but it rubs when drive through some neighborhood with steep inclines and declines..
just send me ur wheels and I will send u my xlites which will never rub. :D :D :D
Old Feb 28, 2006 | 08:18 PM
ScuderiaMini's Avatar
ScuderiaMini
a little dremmeling, prolly two on clock position on the clock, you will be fine, just fine...... notin to worry about
Old Mar 1, 2006 | 06:23 PM
mini552's Avatar
mini552
Have asked this before and still don't have clear answer. I love these wheels and would spend the money for the 16s, and I have no intention of lowering my car ('06 MC). However, I know intuitively and from other threads here that too aggressive an offset is hard on the old wheel bearings. If I'm gonna spend the $$$$ to buy BBS, I don't want it to be an overall negative - On an unlowered Mini, is the 35mm offset OK as far as any damage to bearings or other susp. components? Alex?? Minehune?? Bueller??
Old Mar 2, 2006 | 07:41 AM
Alex@tirerack's Avatar
Alex@tirerack
Being hubcentric with proper bolt engaguemt - I dont think you'll see premature bearing wear based on a 2 mm change from my recomendations.
Scuderamini has the right idea on the solution.
Alex
Old Nov 13, 2006 | 05:34 AM
RacerXSPF's Avatar
RacerXSPF
Has anyone got any pictures of some 16" RG-F's on a lowered MCS?
Old Nov 13, 2006 | 08:19 PM
HC0624's Avatar
HC0624
I lowered mine with KW competition coilovers, is a lot lower then springs. I need to take the inner fender out (plastic piece) and trim it down a bit. I brought a set of 205/55/16 A048 before, but it was too wide for my rear fenders. So I switched them with 195/55/16 instead. But comparing with stock's 205/45/17, the 195/55/16-A048 is wider... I guess is because is R-tires. Just my opinion thou. Hope that helps!
JOHN
Old Nov 14, 2006 | 02:25 AM
RacerXSPF's Avatar
RacerXSPF
WOW!!! That looks great. Thanks. I just ordered 16" RG-F's with 205/50 conti sports. have you ever had 205/50's on those???? Do you know if I will have to do any fender work? I've got H & R coil overs as well. Really looks great! -Sean
Old Nov 14, 2006 | 04:32 AM
mbcoops's Avatar
mbcoops
If the rg-fs are et35 then I believe you will need fender modification. I hear it's quick and easy, and that Alex of the tirerack can be of great assistance.
mb
btw - HCO624 - great wheel/lowering combo. How does it work on the track for you?
Old Nov 14, 2006 | 06:31 AM
HC0624's Avatar
HC0624
mb
Thanks!
The A048 MH compound are great, and they held up extremely well. Highly recommended!!
Cheers,
JOHN
Old Mar 12, 2008 | 09:25 AM
cooper8168's Avatar
cooper8168
Hi, sorry to bump, but I don't think this was answered clearly: what about the RG-F (et35) with the only modification to suspension being the addition of FSD? No rubbing? I understand FSD raises height marginally. Thanks!
smdmini
Oct 7, 2019 06:05 AM
conky
Apr 6, 2016 08:03 PM
pewx3
29
Jan 15, 2016 11:14 AM
molala
Oct 2, 2015 01:53 PM
Tires, Wheels & Brakes
Sep 9, 2015 11:08 AM
