Wheel Pro's only !
Old Feb 13, 2006 | 11:03 AM
Passat774's Avatar
Passat774
Wheel Pro's only !
215/45/17 or 205/45/17 17x8 +35
Ok, 205/45/17 will poke out some and be a little short (stretched look)
Then, 215/45/17 will poke but may rub in the rear.. Will they rub in the front at all ?
Stock height on a 2005 Cooper S
Old Feb 13, 2006 | 11:15 AM
J0kER's Avatar
J0kER
nah they wont in the front (? wat kinda tyres are u usin') rear as u said might but only if u lower it a lot...
sounds like u found sumthin' g00d!!!
Old Feb 13, 2006 | 12:11 PM
MisterDangerPants's Avatar
MisterDangerPants
"d6-mcs" had 17x8 and claimed everything was fine (on a lowered car), although I think he may have been using 205/40/17 in the front. Do a search on his handle and you'll find a lot. I'm going to run 17x7.5 ET35 w/215/45/17 in the spring and have been told from a few folks that it's be fine. I also am running a stock suspension.
Old Feb 13, 2006 | 12:17 PM
ScuderiaMini's Avatar
ScuderiaMini
on a 35mm offset, I would use 215/40/17, in order to minimize possible problems.
Old Feb 13, 2006 | 12:21 PM
onasled's Avatar
onasled
Your pushing it to put a 205 on an 8" rim.
I would say that you 'could' rub with a 205 and 'will' rub with a 215 with only a 35 offset. You car is stock height so you might be lucky.
What rim is this? Sounds like you more into trhe looks rather then function? If so then it's all up to you.
Old Feb 13, 2006 | 12:42 PM
Passat774's Avatar
Passat774
New, wheels just coming out..
Nice BBS mesh style , with a real chrome lip !!
They also are offering a 17x9 !! +35
Old Feb 13, 2006 | 02:49 PM
onasled's Avatar
onasled
Where??
Old Feb 13, 2006 | 04:33 PM
Passat774's Avatar
Passat774
Thanks for the help !! I should have them with a week or so then I can post all the details !
Old Feb 13, 2006 | 04:39 PM
onasled's Avatar
onasled
where are these wheels from. I'd like to see them.
Old Feb 13, 2006 | 04:47 PM
Passat774's Avatar
Passat774
onasled in the snow
YGM
Old Feb 13, 2006 | 04:50 PM
J0kER's Avatar
J0kER
17x9's get out of here !? u did find sum k00l sheit
Old Feb 13, 2006 | 04:59 PM
ScuderiaMini
and will you ever learn English, even I did
Old Feb 13, 2006 | 05:05 PM
J0kER's Avatar
J0kER
u didnt learn, u conformed
Old Feb 13, 2006 | 05:08 PM
Passat774's Avatar
Passat774
I was scared too the first time he emailed me!
But I figured out he normal just like koopers like me..
Old Feb 13, 2006 | 05:15 PM
J0kER's Avatar
J0kER
i assume ur talkin' bout me?
oh, i emailed u first!?:impatient wut are u tryin' to say about me?
Old Feb 13, 2006 | 05:23 PM
Passat774's Avatar
Passat774
I think.. Once I was selling some wheels that you might have liked.. Wait I have only had one set of wheels on my Cooper...
um, this year
Old Feb 13, 2006 | 05:32 PM
J0kER's Avatar
J0kER
huh!
Old Feb 13, 2006 | 05:34 PM
J0kER's Avatar
J0kER
so anyways! ?is it safe to say, ur not goin' to say watcha gettin' next?
from one wheel junkie to another
Old Feb 13, 2006 | 06:21 PM
ScuderiaMini
Old Feb 13, 2006 | 07:12 PM
Passat774's Avatar
Passat774
yeap, as cool as the wheels are I am going to rebadge them some no one well ever know what kinda of wheels they are
Old Feb 14, 2006 | 01:37 PM
Passat774's Avatar
Passat774
Here is the tech info:
18x9.5 4x100/4.50 +35 6.13 Backspace could these even work ??
18x8.5 4x100/4.50 +35 6.13 Backspace could these maybe work?
18x7.5 4x100/4.50 +42 5.90 Backspace
17x9 4x100/4.50 +35 6.38 Backspace
17x8 4x100/4.50 +35 5.88 Backspace will proably get these
17x7 4x100/4.50 +40 5.57 Backspace
Old Feb 15, 2006 | 07:28 AM
Passat774's Avatar
Passat774
New picture of what's to come !
Old Feb 15, 2006 | 01:55 PM
Passat774's Avatar
Passat774
I figured out they are Drifz wheels !!!
Old Feb 15, 2006 | 02:01 PM
ScuderiaMini
like them
Old Feb 15, 2006 | 04:24 PM
Passat774's Avatar
Passat774
I got to see the 17x8 and the wheel above is at least a 9" or 9.5" wide.. The 17x8 did not have as deep of a lip as the one pictured above..
A cool option if someone wants to get wide wheels.. Also, found out the wheels have the chrome lip pressed onto the wheel. Looks like very good quailty paint too.. So, they are simulated 2 pc wheels.. Pretty heavy more for show than go... But proably not as heavy as S-lites
We should see our vendors out there having them soon...
woodstudio
Mar 15, 2020 08:28 AM
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
eastport_mini
General Mini related Ads
Mar 28, 2016 08:35 PM
wheresaldo
Oct 23, 2015 10:17 AM
