5 stud conversion possible?
Old Dec 8, 2005 | 02:57 PM
MiniFr34k's Avatar
MiniFr34k
Hi Everyone
Ive grown tired of finding rims that i love only to realise they are 5 stud and not 4 stud pattern.
Does anyone know if its possible to do a 5 stud pattern conversion on the MCS? Might be a silly question but i thought id ask.
Thanks for the help.
Old Dec 8, 2005 | 03:03 PM
J0kER's Avatar
J0kER
same problem here
DiTTO.................
.......anyone
Old Dec 8, 2005 | 03:30 PM
MiniFr34k's Avatar
MiniFr34k
i know that with honda's can do this
eg:
swap civic type r to civic swap integra type r to normal integra
Old Dec 8, 2005 | 03:32 PM
ugly_duckling's Avatar
ugly_duckling
I heard it is not a safe thing to do unless you really want to compromise the performance for looks.
Old Dec 8, 2005 | 03:43 PM
MiniFr34k's Avatar
MiniFr34k
how is the performance compromised from the change in the stud pattern?
Old Dec 8, 2005 | 03:44 PM
not-so-rednwhitecooper
any machine shop should be able to redrill the stud holes
Old Dec 8, 2005 | 03:54 PM
J0kER's Avatar
J0kER
:oD :0D ;oD
true dat,
but u still want them to be trued so as to not cause vibration
Old Dec 8, 2005 | 03:57 PM
its a real simple job, as long as the holes are maked out correctly, equally spaced and centered on the roto, the only other potential problem would be that the holes were fdrilled at and agle, thats kinda hard to do when the roto is secured to the mounting surface of a mill.
Old Dec 8, 2005 | 05:20 PM
MiniFr34k's Avatar
MiniFr34k
so ur basically saying that i can re-drill the holes on the RIMS?
Old Dec 8, 2005 | 05:27 PM
toddtce's Avatar
toddtce
Do a search. Not like this hasn't been discussed before.
"five lug conversion"
There a long thread on it. In summary; forget about it.
Old Dec 8, 2005 | 05:28 PM
no, take the brake rotors off the car and have them redrilled and tapped for a 5 lug pattern, whatever size pattern you would like.
Old Dec 8, 2005 | 05:37 PM
J0kER's Avatar
J0kER
wat?
NO!! on the rotors.........
theres a guy on VWVortex that can re-drill rims though if ur interested
Old Dec 8, 2005 | 05:39 PM
J0kER's Avatar
J0kER
Edit:wat?
never mind, u beat me to it 'not-so-'
Old Dec 8, 2005 | 06:37 PM
toddtce's Avatar
toddtce
Do you guys even have a clue what you're talking about?
"redrill and tap the rotors to the five lug" ??
What do the rotors have to do with this? Take the car apart, review how it's all held together and get back to us on it.
Old Dec 8, 2005 | 06:45 PM
Yucca Patrol's Avatar
Yucca Patrol
Now that is funny!
Old Dec 8, 2005 | 07:27 PM
Hyper!!!Blue!!!'s Avatar
Hyper!!!Blue!!!
You're probably better off getting rims custom drilled, some shops might be willing to special order you some wheels from the factory with the proper offset and lug holes/spacing.
Old Dec 8, 2005 | 08:56 PM
J0kER's Avatar
J0kER
;0D :0) :oD
so! ...wat happened here ?? ?? ??
Old Dec 9, 2005 | 07:07 AM
meb's Avatar
meb
It's un-safe if you're considering modifying the stock components. Otherwise, a five bolt set-up is stronger than a four bolt.
With regard to the Honda, Acura Type-R (becasue they're easier to get) components are used; larger axles and CV joints, bearings, brakes, calipers and rotors - oh and new wheels. About $5,000 dollars...
The plus side, the NSX calipers will fit Type-R hubs...add another, I don't know, $2,000.00
All said, this is a bolt-on modification with readily available parts that costs $5,000-$7,000 dollars. Dunno what a properly designed and built one-off would be for a Mini - lots more.
Old Dec 9, 2005 | 07:20 AM
Samurai Will's Avatar
Samurai Will
Oh, gee, it's totally unsafe and never been done.
Suuuuure...
Or maybe it has.
Old Dec 9, 2005 | 07:45 AM
Squirlz's Avatar
Squirlz
They're talking about doing it to a car that actually gets DRIVEN
Old Dec 9, 2005 | 10:33 AM
ScuderiaMini's Avatar
ScuderiaMini
forget about it
would not even think about it.
Old Dec 9, 2005 | 10:46 AM
kenchan's Avatar
kenchan
well, with a body kit like that, you can fit a 25mm lug conversion spacer...
but on a typical MINI, you'll have to find a wheel like in the +70mm.
Old Dec 11, 2005 | 06:43 PM
MiniFr34k's Avatar
MiniFr34k
lol *sigh* i guess i just have to keep on searching
Old Dec 11, 2005 | 06:48 PM
toddtce's Avatar
toddtce
Thinking back on this one for you, if you retain the current bolt circle and simply convert to 5 lug that's not going to be as much of a problem. You'll re use one of the current holes and have two others very close to the old ones. If, on the other hand, you want to got to a larger BC then you've got a mess on your hands.
NYMADMINI
Dec 14, 2016 02:33 PM
vetsvette
Oct 11, 2015 06:05 PM
Oct 1, 2015 12:13 PM
Sep 29, 2015 12:11 PM
