Brake Caliper Dust Boot Replacement
Subscribe
Aug 17, 2010 | 01:51 PM
  #26
The rebuild kits I received from Classic for the rears only had the piston boots - actually did not remove the calipers from the car to do the rears as just did the boots as those were the only parts available for the rebuild (and really the only damaged parts due to track event and the low miles on the car). However, it was a major PITA to get the new piston boots properly seated on the caliper as the surround clip continued to pop off. That portion of the job took longer than anything else.
The front rebuilds are pretty straight-forward, did remove the calipers in order to replace the inner seal obviously. Word of caution however, after blasting brake fluid all over myself, the garage and the wife's car on the first caliper when blowing out the brake piston with compressed air, did the second caliper in a garbage sack to minimize the mess - much cleaner
Reply 1
Aug 18, 2010 | 09:42 PM
  #27
needle nose pliers, tapping on the plug with a small hammer. twist. should come unloose, eventually. some liquid wrench around it should help.
Reply 0
Oct 12, 2010 | 10:06 PM
  #28
Torn Rear Boots Suck
While replacing the rear pads on my 2004 MCS I noticed a tear on the passenger side caliper boot. I am about to order the repair kit and was wondering if anyone has a copy of the repair procedure referenced on the first page of this thread? When using compressed air to push out the piston, where is the air line attached and what sort of adapter will be necessary?
If someone sends me some barebones instructions, I'll take pictures of the repair process while I rebuild the caliper and make a DIY Guide for the procedure.
Reply 0
Oct 13, 2010 | 06:24 AM
  #29
It's not necessary to remove the piston or rear caliper when rebuilding the rears with new piston dust boots. Install of the boots is a little tricky, otherwise pretty straightforward DIY.
Reply 0
Feb 19, 2011 | 05:58 PM
  #30
Is it pretty much the same procedure to rebuild and replace boots for the JCW calipers? Any idea how much they cost?
Reply 0
Feb 19, 2011 | 08:51 PM
  #31
Quote: Is it pretty much the same procedure to rebuild and replace boots for the JCW calipers? Any idea how much they cost?
Ok, so I don't need an entire rebuild kit, just the rubber dust boot cover. Per realoem.com I am asuming it is "REPAIR SET BRAKE CALIPER" P/N 34116769277 correct?
Reply 0
Feb 16, 2014 | 05:17 PM
  #32
I just did rear brake boots on my mini cooper S(2004)
It was PIA to put it new boot on caliper.
there is no enough space and one side in, then the other side not. if you push the other side in, one side not,...and again and again.
So what I did was push a flat driver at the bottom part(using my foot) and same time use my finger to push in left top part and right top part same time. You will under stand when you are doing.
Anyway, after it stay, i use flat driver pushed evenly around of new boot.
Here is a tip.
You don't have to push and take out piston.( I did and it become so mass and if I didn't take the piston out, I could save tons of time and energy.
Good luck. =)
Reply 0
Oct 28, 2015 | 07:53 PM
  #33
Here is a tip.
Good luck. =)
I just replaced my dust boots on my 05. It got so very frustrating that I made my own tool! I now have a prototype and will make it available soon! It makes installation a quick, easy and painless process!
Reply 0
Feb 15, 2017 | 05:55 PM
  #34
Quote: I just replaced my dust boots on my 05. It got so very frustrating that I made my own tool! I now have a prototype and will make it available soon! It makes installation a quick, easy and painless process!
Hello Ccoach, did you ever get around to making that brake tool available? I'm about to do my rear brakes. Thanks
Reply 0
Aug 14, 2017 | 07:42 AM
  #35
I replaced one this weekend. I didn't see any sort of clip that held the boot to the caliper in the back. Obviously, the front fits around the caliper lip, but the back just seemed to be press-fit in. Can anyone confirm this?
Reply 0
Subscribe
