Pirellis
Old Sep 7, 2005 | 08:09 PM
ScuderiaMini's Avatar
ScuderiaMini
Pirellis
Pirelli PZero Corsa 215-45-17
Any feedback?
Old Sep 7, 2005 | 08:55 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Any feedback?
PZero Corsa tires are for track competition/lapping and at $220 each from tirerack are quite expensive for most of us. That is a good size for track use however and if you can afford it then give Alex@tirerack.com a call.
http://www.tirerack.com/a.jsp?a=EZ3&url=/tires/tires.jsptireMake=Pirelli&tireModel=PZero+Corsa
Note: Unlike other Pirelli P Zero Corsa tires, the 215/45R17 87Y size features a unique tread compound molded into an 8/32” deep directional tread design. It is assigned a UTQG rating of 140 AA A.
An alternative might be the Michelin Pilot Sport Cup in 225/45-17 at $208 each but that runs a bit tall at 25.1" outer tire diameter and might rub a bit especially if your MINI is lowered. With Coil over suspension you can adjust ride height for clearance or trim the inner rear wheel wells with a dremmel tool. Tread wear is not as good as the PZero Corsa.
http://www.tirerack.com/a.jsp?a=EZ3&url=/tires/tires.jsp&tireMake=Michelin&tireModel=Pilot+Sport+ Cup
Another alternative is the Yokohama Advan A048
in 215/45-17 at $225 each
http://www.tirerack.com/a.jsp?a=EZ3&url=/tires/tires.jsp&tireMake=Yokohama&tireModel=ADVAN+A048
Available in medium and medium hard compound but wears fast.
Old Sep 9, 2005 | 07:32 PM
ScuderiaMini
thank you for the info, appreciate it
Berk
Rgoodwin
Tires, Wheels, & Brakes
Apr 21, 2017 10:56 AM
AoxoMoxoA
Sep 30, 2015 06:00 AM
Brian_in_VT
Sep 18, 2015 05:57 PM
hexproject
Sep 7, 2015 08:23 PM
Kat Maerz
Sep 1, 2015 04:30 PM
