Problem Fitting Wheels
I have been trying to mount my Sendel S70 wheels for auto-x. They are 15x6, 4x100 with a 40 offset. Problem seems to be that the holes for the lugnuts are too narrow for the flared end of the bolt to go in far enough for the bolt to grab the hole in the hub.
What should I do?
What should I do?
There are generally two sorts of lug bolt seats. one is sort of a acorn-shaped curve, the other is a cone. I forget which the MINI uses.
So first thing you need to do is make sure you're using bolts with the right type of seat. Sounds like you might need cones (acorns don't seat well in a cone hole, as you might expect.)
There are also a variety of lengths available. If you're not getting enough threads into the hub, get longer bolts. Most autoparts stores carry a selection of bolts in both chrome and black.
Stick an OE bolt in an OE wheel and see how much thread sticks out the back. Now take your new wheel to the store and find a bolt to give you a similar amount of thread sticking out, with a seat that matches your wheel.
Sometimes you'll find bolts in blister packs on the shelf, but you'll also find them in the bolt-bin behind the counter...so you may need to ask.
...david
...david
There are two types of lug nut seats. The Mini Cooper uses a conical seat on the factory wheels and most aftermarket.
The other choice is ball seat. That is used a lot on Mercedes Benz in there OE applications.
If the wheels are ball seat you will need a ball seat lug bolt 12x1.5 thread pitch. Which is not very common.
What would be best is a super close up picture so we can try and see the seat of the wheel.. Or to see where the lug nut is getting stuck..
I agree that I need "tuner" lugs, but apparently there are none that are "tuner" lug bolts...
I will take some pictures of the wheels ASAP. In the interim, I ordered a set of longer bolts from Pilo Racing and will see what happens.
Thanks for the input!
If the seats don't match, it doesn't matter if you have longer bolts. You may grab more threads but the mismatched seats will probably damage the wheels and will for sure be a dangerous situation. I wouldn't even think about it.
Use your orginal equipment bolts for your orginal equipment wheels.
Does the wheel sit up tight against the mounting pad without lug bolts?
Can you balance the wheel flat against the mounting pad?
If yes than it's the bolts if no something is not right with the wheel.
Again try and take some pictures, I understand that it is very hard to sometimes to describe with words what is wrong..
SosoMINI
Nov 22, 2015 03:17 PM
Mini'mon
Aug 16, 2015 04:15 PM
Aug 12, 2015 01:24 PM
