17" BBS RG-R centering ring question
You can probably re-use the stock lugs, just make sure the tapering in the
wheel lug holes are the same as your lugs.
If the wheel sits on the center hub properly without any looseness
(you can tell right off the bat),
then the wheels are already hub-centric. I believe Alex sells RG-R's
over at the tirerack so you might be able to get a set from him if
needed. :smile:
needed. :smile:
The rings are there so the wheel fit hub centric. The hub is what centers and locates the wheel not the lug bolts. The centering rings allow the wheel manufacturer to make a wheel that can be used in other applications. The RGR wheels are same fitment for some Hondas. I would get a set of correct ring. I had my wheels for ~ 2 years, BBS may have change the wheels and do not require the rings. I would check with BBS.
Thanks again for lending me your expertise.
Mini'mon
Aug 16, 2015 04:15 PM
Aug 12, 2015 01:24 PM
Aug 7, 2015 05:55 AM
