+38 17x7 what tire size ?
Old Feb 9, 2005 | 07:22 PM
Passat774's Avatar
Passat774
I know that the 205/45/17 will work fine. My questions really lies in terms of a 215/45/17. Will it rub at stock height? Will it rub lowered on a Pro-Kit.. Does it mean just some rubbing in the back, that a dremel can easily fix?
My logic has always been the larger the side wall the more protection for the beautiful rims that we buy and a more comfortable ride we would get
Old Feb 9, 2005 | 07:47 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Using stock suspension and 215/45-17 tires will not rub and be fine.
Upgrading to Eibach Pro-kit or other springs that lower the MINI 1" or more front and rear will require rims that are within the offset range of about +42mm to +50mm. Rims with offsets of +38mm will likely rub in the rear but a dremmel can cut the inner wheel liner to make more room. Another option with the +38mm offset wheel is to consider 215/40-17 tires but that would make the ride quality a bit harsher and sometimes the selection of tires is a bit different and cost a bit higher.
When you use 225/45-17 tires then there is much more need to dremmel trim the rear inner wheel well.
Old Feb 10, 2005 | 04:56 PM
Passat774's Avatar
Passat774
Thanks man for the information. You are a great help, and I appericate the fact that you take the time to answer more than your far share of posts
I will now get the new Fuzion HRi 215/45/17 they should be out in the next few weeks.
Kimolaoha
Dec 5, 2020 09:32 PM
kazyn
Oct 25, 2019 02:34 PM
DrFraserCrane
Aug 30, 2015 01:11 PM
col127
Aug 21, 2015 02:11 PM
Edgar78
Aug 15, 2015 05:33 AM
